Webcast-Catalyst9k
cisco 3750x 24 port poe switch failure
what is the chance of cisco 3750x 24 port poe switch failure? is backup necessary for this ? please answer me in details.
Hall of Fame Super Gold
If you have a Cisco switch
If you have a Cisco switch with, at least, one faulty port you RMA the appliance.
There is nothing more detailed than that.
back up is necessary for
back up is necessary for cisco 3750x ?
This discussion has been
This discussion has been reposted from Cisco User Groups to the LAN, Switching and Routing community.
If you want to keep your
If you want to keep your configuration yes make sure you backup.
To backup setup a TFTP server (TFTP 32 is good for this) and run the following command on the switch and follow the prompts: copy running-config tftp
To restore the configuration on your new switch: copy tftp running-config
Make sure you save your configuration by running after you have restored the backup: copy running-config startup-config
155
