Cisco 3750X as a NTP master
Hi All,
I would like to configure my core switches as the ntp master for the environment but also I would like to have the core switch sync with a public NTP server. Can you advise if this is possible? I have seen both commands available on the switch.
1 REPLY
Hall of Fame Super Gold
It is possible but you do not
It is possible but you do not have to use the command "ntp master" on your switch.  Point all your device to the switch and it should work.
The switch should be able to synchronize NTP with a trusted source.
57
