cisco 3750X stack
I have 2 cisco 3750X in stack
in sh logging i have flood message:
Mar  3 19:31:57.635:  hlfm_pd_to_pi_mat_table_type: Invavid platform addr type : 0 (switch-2)
Mar  3 19:32:05.704:  hlfm_pd_to_pi_mat_table_type: Invavid platform addr type : 0 (switch-2)
Mar  3 19:32:15.771:  hlfm_pd_to_pi_mat_table_type: Invavid platform addr type : 0 (switch-2)
Mar  3 19:32:26.844:  hlfm_pd_to_pi_mat_table_type: Invavid platform addr type : 0 (switch-2)
Mar  3 19:32:26.852:  hlfm_pd_to_pi_mat_table_type: Invavid platform addr type : 0 (switch-2)
help me plz how to fix it ?
2 ACCEPTED SOLUTIONS
Re: cisco 3750X stack
You have different version of IOS. The member have higher version than the master.
By right, when a new member is added to the stack, the master switch will download its image to the new switch, send the stack configuration and enable it.
I have not encountered this error as I make sure the image of all switches are the same before I built a stack. I also make sure that the image of the new switch to be added in the stack is the same version with the master (or lower) - not higher.
Since the image of Switch-2 didn't change and its higher than the master switch, that could be the reason you have those error. Maybe manually changing the image will help (or change the master).
Hall of Fame Super Gold
cisco 3750X stack
*    1 30    WS-C3750X-24       12.2(58)SE2           C3750E-UNIVERSALK9NPE-M
2 30    WS-C3750X-24       15.0(1)SE             C3750E-UNIVERSALK9NPE-M
Like what everyone has posted, your stack is running two different IOS versions.
cisco 3750X stack
Not enough info.
Can you please post to the command "sh version"?
cisco 3750X stack
switch#sh version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9NPE-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 01:23 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
switch uptime is 6 days, 21 hours, 14 minutes
System image file is "flash:/c3750e-universalk9npe-mz.122-58.SE2/c3750e-universalk9npe-mz.122-58.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1546V03X
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
56 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 28:94:0F:4E:CD:80
Motherboard assembly number     : 73-12530-05
Motherboard serial number       : FDO15461GBG
Model revision number           : A0
Motherboard revision number     : C0
Model number                    : WS-C3750X-24T-S
Daughterboard assembly number   : 800-32727-01
Daughterboard serial number     : FDO15461CEZ
System serial number            : FDO1546V03X
Top Assembly Part Number        : 800-31327-02
Top Assembly Revision Number    : E0
Version ID                      : V02
CLEI Code Number                : COMJV00ARB
Hardware Board Revision Number  : 0x03
Switch Ports Model              SW Version            SW Image
Switch 02
Switch Uptime                   : 6 days, 21 hours, 15 minutes
Base ethernet MAC Address       : C4:64:13:6C:8C:00
Motherboard serial number       : FDO155010E6
Daughterboard serial number     : FDO15501P7Q
System serial number            : FDO1549R1Z0
Top assembly part number        : 800-31327-02
Top assembly revision number    : E0
Version ID                      : V02
License Level                   : ipbase
License Type                    : Permanent
Next reboot licensing Level     : ipbase
Configuration register is 0xF
Bronze
cisco 3750X stack
Hi Danilo,
Are you sure about the image download to member stack switches from master automatically(and also not by using archive download-sw command)??
I am not able to get any document saying that happens...
Infact, earlier i did try connecting a lower IOS version than master switch on a stack, and i left for 1 hour, still the image transfer hadn't happened from master to the member, and no log messages too.........., so i believe image transfer doesn't happen between master and member switch unless we issue copy IOS ourself from one flash to another.......
Please confirm/clarify...
Manjunath
Hi Maju,
Here is the link http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_white_paper09186a00801b096a.html
Look for "Automatic Cisco IOS Software Upgrade/Downgrade from the Master Switch"
Best wishes,
Dandy
cisco 3750X stack
cisco 3750X stack
Big Thx for all
The problem was the difference IOS versions
what did I do:
1. change master switch (switch 2 priority 15) did not help me - the master has not updated automatically other switch in stack.
2. I upgrade IOS on switch-1 manual. I get IOS 15.0(1)SE from switch 2
copy flash2:/c3750e-universalk9npe-mz.15-0.SE/c3750e-universalk9npe-mz.15-0.SE.bin tftp://10.0.0.2
clear space on flash1 after backup files
copy flash1:/c3750e-universalk9npe-mz.122-58.SE2/c3750-ipbase.122-58.SE2.tar tftp://10.0.0.2
delete flash1:/c3750e-universalk9npe-mz.122-58.SE2/c3750-ipbase.122-58.SE2.tar
mkdir flash1:/c3750e-universalk9npe-mz.150-1.SE/
copy tftp://10.0.0.2/c3750e-universalk9npe-mz.150-1.SE.bin flash1:/c3750e-universalk9npe-mz.150-1.SE/c3750e-universalk9npe-mz.150-1.SE.bin
conf t
boot system switch 1 flash:/c3750e-universalk9npe-mz.150-1.SE/c3750e-universalk9npe-mz.150-1.SE.bin
exit
write mem
reload
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9NPE-M), Version 15.0(1)SE, RELEASE SOFTWARE (fc1)
Compiled Wed 20-Jul-11 09:09 by prod_rel_team
switch uptime is 36 minutes
System image file is "flash:/c3750e-universalk9npe-mz.150-1.SE/c3750e-universalk9npe-mz.150-1.SE.bin"
export@cisco.com.
Version ID                      : V02
*    1 30    WS-C3750X-24       15.0(1)SE             C3750E-UNIVERSALK9NPE-M
Switch 02
Switch Uptime                   : 36 minutes
Version ID                      : V02
And no errors in log.
after i back master switch to swicth-1.
Yes, you can do that also. I'm not sure yesterday so I didn't include in my email - though I tempted to add
1624
