CIsco 3825 Troubleshooting
Kindly help me in troubleshooting the issue explained below..
*Sep  9 08:11:17.213: %FAN-3-FAN_FAILED: Fan 2 had a rotation error reported.
*Sep  9 08:11:37.233: %FAN-3-FAN_FAILED: Fan 2 had a rotation error reported.
% Password:  timeout expired!
Password:
*Sep  9 08:11:57.345: %FAN-3-FAN_FAILED: Fan 2 had a rotation error reported.
Password:
*Sep  9 08:12:17.361: %FAN-3-FAN_FAILED: Fan 2 had a rotation error reported.
*Sep  9 08:12:37.361: %FAN-3-FAN_FAILED: Fan 2 had a rotation error reported.
% Bad secrets
DRILS>
*Sep  9 08:12:57.489: %FAN-3-FAN_FAILED: Fan 2 had a rotation error reported.
DRILS>
DRILS>s
*Sep  9 08:13:17.489: %FAN-3-FAN_FAILED: Fan 2 had a rotation error reported.h inve
sh env
 Redundant Power System is not present.
 SYS PS1 is present.
    Type: AC
 AUX(-48V) PS1 is absent.
 Fan  1 Normal
 Fan  2 Failed
 Fan  3 Normal
 Fan Speed is Normal
 Alert settings:
 Intake temperature warning: Enabled, Threshold: 55
 Core temperature warning: Enabled, Threshold: 70 (CPU: 95)
 Board Temperature: Normal
 Internal-ambient temperature = 30, Normal
 CPU temperature = 45, Normal
 Intake temperature = 26, Normal
 Voltage 1(3300) is Normal, Current voltage = 3300 mV
 --More--          Voltage 2(5150) is Normal, Current voltage = 5210 mV
 Voltage 3(2500) is Normal, Current voltage = 2525 mV
 Voltage 4(1200) is Normal, Current voltage = 1203 mV
 Nominal frequency
Thanks in advance
~Kiku
1 ACCEPTED SOLUTION
Kiku,You can just replace the
Kiku,
You can just replace the Fan tray rather than replacing te complete box.
Here is the part number for 3825:
ACS-3825-FANS=
3825 Fan assembly
You need to replace the complet fan assenbly not the one of the fan on the tray.
Below is the procedure to replace the same:
http://www.cisco.com/c/en/us/td/docs/routers/access/3800/hardware/installation/guide/hw/38comp.html
Q. Can you perform OIR on the fan tray?
A. Yes. The fan tray can be removed in a Cisco 3845 while the router is fully operational in order to service a redundant power supply. In  high-temperature environments, the fan tray should be reinstalled in a few minutes.
Question on creating the RMA:
Called the Cisco and provide the serial number of your device or cisco contract ID associated with this box and they would be able to raise the case for you.
Inayath
**Plz rate if this info is helpfull.
Hall of Fame Super Gold
Raise a Cisco TAC Case (upper
Raise a Cisco TAC Case (upper right-hand corner, under "Action").
TAC should send you a fan assembly including instructions on how to replace them.
Hi Leo,Is RMA is needed
Hi Leo,
Is RMA  needed?
~Kiku
Kiku,Yes you need to get the
Kiku,
Yes you need to get the FAn tray RMA. As based on the above output:
 Fan  2 Failed>.. Fan 2 has been failed.
There is nothing much troubleshooting can be done on the Fan tray.
I suspect the part number to be:CISCO3845FANASSY=
You can raise TAC case and ask them for RMA this part if you have the valid contract with cisco.
We are thinking of raising an
We are thinking of raising an RMA,but my doubt is whether to raise RMA on Fan assy or complete Router.Because we cannot get the part number through console output,also i cannot open the Router and note the Fan part number.
I think part number is necessary to raise an RMA,and also how can we identify that particular fan is Fan-2,are they labelled ?
If i cannot trace the part number ,what should be done in this case?Kindly suggest .
Kiku
Kiku,
ACS-3825-FANS=
3825 Fan assembly
Inayath
Thank you Leo and Inayath for
Thank you Leo and Inayath for your valuable suggestions.
91
