11-28-2011 02:04 AM - edited 03-07-2019 03:37 AM
In my cisco 3845 router I can see output packet drop in some of the interfaces.I suspect that router is processing packet beyond its mix throughput limit. Moreover when i run show int fax/y switching command I can see packet drop by RP process. Can you please help me to troubleshoot this issue.
11-28-2011 02:07 AM
Maybe if you post a show run, and some other information on what's ther is attached to that interface, how is configrured, on both side we can try to help you.
11-28-2011 02:48 AM
This router is connected with one C2950 switch in downstream direction and with one ISP router in upstream direction. Router has five interfaces(Fe) connected with C2950 switch and they are assigned with different IP subnet. All ports of
C2950 switch are in default VLAN 1 and furtherC2950 switch is connected with 5 L3 switches. All ports of L3 switches are also in default VLAN 1 but servers are assigned with different IP pool as servers are connected to different switches.
11-28-2011 03:18 AM
This router with 5 interface are connected all on the same switch or there are 5 switch with different ip address and subnet ? Can you send a running config of switch and router and a topology scheme?
11-28-2011 03:59 AM
HI Please find the above connectivity diagram.The router with 5 interface are connected all on the same switch. All the ports of the all switches are in VLAN1. But servers are segregated with different subnets and accordingly network defined with router interface. I know, the design is not as per standard but my cencern is why output drop happening with router interface.
11-28-2011 05:09 AM
So, you have interfaces routed connected in access on one switch, all in one broadcast domain, and the hsrp standby configuration is not in use with any other router. From design perspective is horrible. Can you put the output of drop and the interface interested in this behavior?
11-28-2011 06:43 AM
11-28-2011 06:47 AM
Cdp are enabled on switch port connected and on router port?
11-28-2011 07:03 AM
Yes. CDP is enabled on all ports.
11-28-2011 07:18 AM
the 20% you refer to unknown protocol drops? because i don't see particular crc or tx/rx load. If yes are you sure on your network there aren't any other protocol than ip for example appletalk, ipx, ipv6?
11-28-2011 07:27 AM
Check the line of my output: Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3000. Here is showing output drop.
11-28-2011 07:35 AM
Yes, i've see that, but the interface is only fa 1/12. The interface is in auto 100 auto ful? From router and switch side? Or one of interface is in half or with different speed?
