CISCO 3850 PoE+ SWITCHES
I have a device which work on PoE (IEEE802.3af).
Is it possible to sent the data + power to the PoE device by use of Cisco PoE+ (IEEE802.3at) i.e Could PoE+ Switches (IEEE802.3at) support the PoE Devices (IEEE802.3af).
Please help.
Amey
Everyone's tags (1)
1 REPLY
Silver
Re: CISCO 3850 PoE+ SWITCHES
See this:
3850 PoE, PoE+, and Cisco UPOE Ports
The PoE+ and Cisco Universal Power Over Ethernet (Cisco UPOE) ports use the same connectors as described in the "10/100/1000 Ethernet Ports" section.
They provide:
•PoE+ ports: Support for IEEE 802.3af-compliant powered devices (up to 15.4 W PoE per port) and support for IEEE 802.3at-compliant powered devices (up to 30 W PoE+ per port). The maximum total PoE power in a 1RU switch is 1800 W.
•Cisco UPOE ports: Support for powered devices on all four Ethernet signal pairs (up to 60 W Cisco UPOE per port).
•Support for Cisco-enhanced PoE.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3850/hardware/installation/guide/HIGOVERV.html#wp1351798
227
