Blue
Cisco 4006
Does the Cisco 4000 series switch support IOS or is it just Cat OS?
Cant remember and need an answer quickly...
Victor
1 ACCEPTED SOLUTION
Purple
Re: Cisco 4006
Supp II or below is catos only. Sup II+ and above is IOS . If its running catos currently you cannot upgrade it without getting a newer supervisor.
Hall of Fame Super Blue
Re: Cisco 4006
Victor
A 4006 can run IOS but is dependent on your Supervisor. I believe you need a SupIII or later.
Jon
Purple
Re: Cisco 4006
Blue
Re: Cisco 4006
Thanks, guys.
264
