Cisco 4500 Auto-QOS on Ether-Channel
Cisco's documentation suggests that auto-qos feature is not supported on ether-channel interfaces. Enabling auto-qos on non-etherchannel interfaces generated all the global qos related configuration and applied service-policy to the interfaces. However, when I try to manually apply the generated service-policy to member-interfaces in an etherchannel, it fails with the following error message.
(config-if)# service-policy input AutoQos-4.0-Input-Policy
class-map match any is not supported for this interface
(config-if)# service-policy output AutoQos-4.0-Output-Policy
% A service-policy with more than one  type of marking field based filters in the  class-map is not allowed on the channel member ports.
There does not seem to a command available as "qos trust cos" or "qos trust dscp":
(config-if)#qos trust ?
  device  trusted device class
  extend  Extend trust through a connected device
The platform is Cisco 4507R+E with Sup-7L-E in VSS mode running 3.4.0 SG (15.1-2 SG). I just need to trust cos/dscp marking on certain etherchannel trunk / access links and prioritise marked traffic (voice/video) on them. Enabling auto-qos on normal interfaces (non-etherchannel) generated the following config.
class-map match-all AutoQos-4.0-Scavenger-Classify
  match access-group name AutoQos-4.0-ACL-Scavenger
class-map match-all AutoQos-4.0-Signaling-Classify
  match access-group name AutoQos-4.0-ACL-Signaling
class-map match-any AutoQos-4.0-Priority-Queue
  match cos  5
  match  dscp ef
  match  dscp cs5
  match  dscp cs4
class-map match-all AutoQos-4.0-VoIP-Data-Cos
  match cos  5
class-map match-any AutoQos-4.0-Multimedia-Stream-Queue
  match  dscp af31
  match  dscp af32
  match  dscp af33
class-map match-all AutoQos-4.0-Network-Mgmt
  match  dscp cs2
class-map match-all AutoQos-4.0-VoIP-Signal-Cos
  match cos  3
class-map match-any AutoQos-4.0-Multimedia-Conf-Queue
  match cos  4
  match  dscp af41
  match  dscp af42
  match  dscp af43
  match access-group name AutoQos-4.0-ACL-Multimedia-Conf
class-map match-any AutoQos-4.0-Transaction-Data
  match  dscp af21
  match  dscp af22
  match  dscp af23
class-map match-all AutoQos-4.0-Network-Ctrl
  match  dscp cs7
  match  dscp cs1
class-map match-all AutoQos-4.0-Default-Classify
  match access-group name AutoQos-4.0-ACL-Default
class-map match-any AutoQos-4.0-Signaling
  match  dscp cs3
  match cos  3
class-map match-any AutoQos-4.0-Bulk-Data-Queue
  match cos  1
  match  dscp af11
  match  dscp af12
  match  dscp af13
  match access-group name AutoQos-4.0-ACL-Bulk-Data
class-map match-all AutoQos-4.0-Transaction-Classify
  match access-group name AutoQos-4.0-ACL-Transactional-Data
class-map match-all AutoQos-4.0-Broadcast-Vid
  match  dscp cs5
  match  dscp af11
  match  dscp af12
  match  dscp af13
class-map match-any AutoQos-4.0-Scavenger-Queue
  match  dscp cs1
  match cos  1
class-map match-any AutoQos-4.0-VoIP
  match  dscp ef
  match cos  5
  match  dscp af41
  match  dscp af42
  match  dscp af43
class-map match-any AutoQos-4.0-Control-Mgmt-Queue
  match cos  3
  match  dscp cs7
  match  dscp cs6
  match  dscp cs3
  match  dscp cs2
class-map match-all AutoQos-4.0-Bulk-Data-Classify
class-map match-any AutoQos-4.0-Trans-Data-Queue
  match cos  2
  match  dscp af21
  match  dscp af22
  match  dscp af23
  match  dscp af31
  match  dscp af32
  match  dscp af33
class-map match-any AutoQos-4.0-VoIP-Data
  match  dscp ef
  match cos  5
class-map match-all AutoQos-4.0-Internetwork-Ctrl
  match  dscp cs6
class-map match-all AutoQos-4.0-Realtime-Interact
  match  dscp cs4
class-map match-all AutoQos-4.0-Multimedia-Conf-Classify
class-map match-any AutoQos-4.0-VoIP-Signal
  match  dscp cs3
  match cos  3
policy-map AutoQos-4.0-Input-Policy
class AutoQos-4.0-VoIP
class AutoQos-4.0-Broadcast-Vid
class AutoQos-4.0-Realtime-Interact
class AutoQos-4.0-Network-Ctrl
class AutoQos-4.0-Internetwork-Ctrl
class AutoQos-4.0-Signaling
class AutoQos-4.0-Network-Mgmt
class AutoQos-4.0-Multimedia-Conf
class AutoQos-4.0-Multimedia-Stream
class AutoQos-4.0-Transaction-Data
class AutoQos-4.0-Bulk-Data
class AutoQos-4.0-Scavenger
policy-map AutoQos-4.0-Output-Policy
class AutoQos-4.0-Scavenger-Queue
    bandwidth remaining percent 1
class AutoQos-4.0-Priority-Queue
    priority
    police cir percent 30 bc 33 ms
class AutoQos-4.0-Control-Mgmt-Queue
    bandwidth remaining percent 10
class AutoQos-4.0-Multimedia-Conf-Queue
class AutoQos-4.0-Multimedia-Stream-Queue
class AutoQos-4.0-Trans-Data-Queue
    dbl
class AutoQos-4.0-Bulk-Data-Queue
    bandwidth remaining percent 4
    dbl
class class-default
    bandwidth remaining percent 25
    dbl
<<< ACL's used in the config above >>>
int gi1/6/1
   auto qos trust
Rick.
1 REPLY
Yea, you can't apply to the individual interfaces...  I'm used to not being able to apply to the port-channel itself....  Not sure what in the world is going on....
1269
