12-31-2011 03:43 AM - edited 03-07-2019 04:07 AM
hi
every one i want to know ws-c4503E series 3 -slot chasis .I have compatabilty issues with MEM-C4K-FLD64M AND S45EIPBK9-12240SG will work or not if not please suggest the which is best plz reply as soon as possible thanks
12-31-2011 04:25 AM
Ghulam,
Which sup engine you are talking about? This compatibility is to with the sup engine and the IOS you are using vs the chassis being used.let's know.
12-31-2011 01:24 PM
thanks for ur qiuck reply my company requires 4500E redundant core switch (10 G) for that some technical guy suggest that we need 1. ws-c4503E
2.catalyst 4500 E-series supervisor ,848gbps
3.catalyst 4500 E-series 12-port 10 Gbe (sfp)
4.spf-10g-sr
5.spf-10g-lrm
6.cvr-x2-sfp10g
7.glc-sx-mm
8.s45eipbk9-12240g
9.mem-c4k-fld64m
10.pwr-c45-2800acv
are required to setup my core network
But some cisco guy gaving different senario like from 1-8 are same,item nos 9 and 10 are different he included 9.cat4500e sup7e universal crypto image
10.paper ip based license
My doubt is with flash item nos 9 can we able to start a switch and plz suggest us which is the best solution thanks
