Cisco 4500 IOS
I want to upgrade to the latest IOS for a client of mine. My client has the following image: cat4000-i5k91s-mz.122-25.EWA14.bin
His hardware specifications are as following:
cisco WS-C4510R (MPC8245) processor (revision 4) with 524288K bytes of memory.
Processor board ID FOX102203CC
MPC8245 CPU at 400Mhz, Supervisor V
Last reset from Reload
5 Virtual Ethernet interfaces
152 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
CAT-4510-A#show module
Chassis Type : WS-C4510R
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1     2  Supervisor V 1000BaseX (GBIC)          WS-X4516           JAE10254STS
3    24  10/100/1000BaseT (RJ45)                WS-X4424-GB-RJ45   JAE10223HMJ
4    24  10/100/1000BaseT (RJ45)                WS-X4424-GB-RJ45   JAE10223HME
5    24  10/100/1000BaseT (RJ45)                WS-X4424-GB-RJ45   JAE10223P2V
6     6  SFP, 10/100/1000BaseT (RJ45)V, Cisco/I WS-X4506-GB-T      JAE10223R0H
7    24  10/100/1000BaseT (RJ45)                WS-X4424-GB-RJ45   JAE1126NBWJ
8    24  10/100/1000BaseT (RJ45)                WS-X4424-GB-RJ45   JAE1129QWQW
9    24  10/100/1000BaseT (RJ45)                WS-X4424-GB-RJ45   JAE1349PNXM
We would want an IOS image within the same feature set that can support the following command on the interface configuration menu:
dot1x control-direction in
Thanks in advance.
TIA, Nicos Nicolaides
1 REPLY
Cisco 4500 IOS
You can use feature navigator to locate that:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Nik
235
