Cisco 4500x vty access-class
I have a Cisco 4500x, connected and configured the management interface fa1.
I can ping, telnet, ssh  and so on, and configured the vrf.
I want to restrict access to vty, so I use the default access-class on the vty.
I do that, I lose connections to the cisco 4500x remotely, telnet, ssh does not go through.
Access-list is ok and I can even see the match on the access-list
access-list 120 permit ip host <mypc> <mgt_ip_4500x>
However all connections are blocked.
Can anyone help please.
1 ACCEPTED SOLUTION
Silver
If the interface is in a VRF I think you will need the access-class x in vrf-also command to make it apply to interfaces in VRF as well.
Daniel Dib
CCIE #37149
Please rate helpful posts
Daniel Dib CCIE #37149 Please rate helpful posts.
Silver
Daniel Dib
CCIE #37149
Excellent, it works fine with the vrf-also.
Just to point out works only with standard acl.
370
