11-15-2006 01:05 PM - edited 03-05-2019 12:49 PM
Hi Folks - let me preface by saying I am not all that technical. My issue is that I am trying to figure out the arrangement of ports that will give me a gigabit of connectivity. i.e. my understanding is that on this switch you can plug a device in to port 1 for example and if you leave the other 3 (or so) ports empty then the device connected to port1 will get 1gigabit as opposed to 100mb/s. Can anyone tell me what this configuration is or what ports to plug into and what to leave empty to get 1g/bit? - thanks
11-15-2006 03:21 PM
Not sure what you are saying but if the port is a gig port then that is what it will connect in as a gig , doesn't matter if all the ports connect as gig . It you are talking about oversubsription of a group of ports then you would have to do a search on the specs on the switch .
11-15-2006 03:25 PM
Take a look at this:
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd801792b1.html
It gives you a good idea of the ports & capacity of the 4503
