Community Member
Cisco 4503 Supervisor II Plus
I have a Cisco 4503 Switch with Supervisor engine II plus, and i need to configure OSPF routing on it and it doesn't support. How can i overcome this issue?
Community Member
Re: Cisco 4503 Supervisor II Plus
The Sup II doesn?t support OSPF routing, I thing the only way to overcome this issue is to upgrade to a SUP IV.
See this link for more info.
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet09186a0080197424.html
/Regards Rikard
Hall of Fame Super Bronze
It's a hardware limitation, you need to have Sup IV or later.
If budget is an issue, I recommend getting a router (1800 would do) to run the routing protocol and let the switch handle the layer2 tasks.
bjw Silver
Silver
I believe you'll need at least a SUP IV to do OSPF or any real routing protocol.
Have you tried static routes? I have SUP IIIs on a few 4K6 boxes and can add static routes.
154
