Cisco 4506 Insufficient power available for current chassis configuration!
aramos17428
I'm trying to install 2 new power supplies for a Cisco 4506. The part number of the PS reads 4200ACV. The switch has (4) 48 port POE blades, one routing module and one supervisor engine. I keep getting this message and non on the blades are available as looks like i dont have sufficient power. is this correct or do I have to do something with the switch so it can see the power supplies.
I have include my show enviromen.
Switch#sh environment
no alarm
Chassis Temperature = 35 degrees Celsius
Chassis Over Temperature Threshold = 75 degrees Celsius
Chassis Critical Temperature Threshold = 95 degrees Celsius
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 Unknown Type Unknown bad/off bad/off n.a.
PS2 Unknown Type Unknown bad/off bad/off n.a.
Power supplies needed by system : 1
Power supplies currently available : 0
*** Insufficient power supplies present for specified configuration ***
Chassis Type : WS-C4506
Power consumed by backplane : 0 Watts
Supervisor Led Color : Red
Module 1 Status Led Color : Red
Module 2 Status Led Color : Red
Module 4 Status Led Color : Red
Module 5 Status Led Color : Red
Module 6 Status Led Color : Red
Fantray : Good
Power consumed by Fantray : 50 Watts
Switch#
Armando
Edison Ortiz
It sounds like you don't have the correct power supply for that unit. The chassis can't even display the model number on its config.
You don't have to do anything special, it's plug and play.
Contact the reseller and make sure they sent you the correct part number.
If you have the invoice or the box it came in, it should indicate the Cisco part number. 4200ACV is not a complete part number.
Edit: I did a quick search and found the correct part number (PWR-C45-4200ACV) and it belongs to the Cisco 4500 line so you should be fine. Perhaps they are defective or you don't have enough power from the source (110 or 220v) ?
8 Replies 8
Edison Ortiz
Edison,
Thanks for the reply. Both UPS show status as green. let me check that I'm getting the required power even if all LEDs status are GREEN
PS 1
Input 1 OK
Input 2 OK
PS2
Input 1 OK
Input 2 OK
Wierd, it can even see the power supplies.
Armando
Let's see a show ver.
Show version included.
I believe the required IOS is 12.2.5 or higher, however, It could be that I need a later release. I can't seem to find software for the 4506 chassis in the IOS switch download software.
Switch#sh ver
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5S-M), Version 12.2(25)EW, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Fri 10-Dec-04 14:00 by kellythw
ROM: 12.1(20r)EW1
Dagobah Revision 95, Swamp Revision 28
Switch uptime is 0 minutes
System image file is "bootflash:cat4000-i5s-mz.122-25.EW.bin"
cisco WS-C4506 (MPC8245) processor (revision 7) with 524288K bytes of memory.
Processor board ID FOX083004WJ
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from PowerUp
1 Virtual Ethernet interface
2 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
Go to
http://www.cisco.com/kobayashi/sw-center/
and click on the following links:
Cisco IOS Software
Cisco IOS 12.2
Download Cisco IOS 12.2 Sofware
CAT4500 Sup4
12.2.37 is the current one.
Typically you won't get full rated power out of the PSU unless you're running 220v. I have seen this on 6500 series chassis before. PSU couldn't fully power chassis unless drawing power via 220v.
Edison Ortiz
From
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet09186a00801f3dd9.html
CISCO CATALYST 4500 SERIES DUAL INPUT 4200W POWER SUPPLY
Combined Mode Power Resiliency is an extension of the traditional combined mode power supply behavior; it is only applicable to the 4200W power supply. Each 4200W power supply contains two smaller power supplies (called a sub-unit). In Combined Mode Power Resiliency the system only relies on power from three out of four power supply sub-units. When using 200V AC, this feature ensures that 5500W of power is available while the switch is protected against a single input power failure or sub-unit component failure. When using four 110V AC, Combined Mode Power Resiliency provides up to 2,728 Watts.
thanks for all your responses.
After doing the upgrade the Power supplies were recognized and all the modules started to provide POE as documented
Thanks Edison
ARamos
