Cisco 4506 IOS upgrade
vpersaud001
Level 3
Level 3
I tried upgrading the IOS on a 4506 from cat4500-entservicesk9-mz.122-31.SGA.bin to c4gwy-a3bik9no3rsx3-mz.124-21.bin and received this message "%Warning: File not a valid executable for this system".
Does anyone know what's the latest IOS I can use? Hardware is cisco WS-C4506 (MPC8540). Cisco's software advisor seems to be down for maintenance since yesterday. Thanks.
2 Accepted Solutions
Jon Marshall
Here are the release notes for the latest IOS version on 4500 - 12.2(46)SG1
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_17886.html
Jon
I just look under the product page for the 4500 switches. Under "General Information" link are the release notes and these set of notes are the latest.
Jon
5 Replies 5
Jon Marshall
Jon
Jon...Thank you. Apart from the software advisor how are you able to determine the latest release for specific hardware?
Jon
Great! Thank you very much.
I have Sup V-10GE for which the recommended upgrade is 12.2(31)SGA7. I'll try that one unless you suggest otherwise.
12.2(46)SG is recommended for Supervisor Engine 6-E.
Thanks again.
"I'll try that one unless you suggest otherwise."
If that is the recommended one that's the one to go with :)
Good luck.
Jon
