10-17-2010 12:25 AM - edited 03-06-2019 01:33 PM
WS-C4507R Switch (Supervisor V-10GE / IOS - cat4000-i9k91s-mz.122-25.EWA12.bin) is generating the below logs - %C4K_HWNETFLOWMAN-4-FLOWSLOSTERR: Netflow stats lost either due to hardware hash collisions or full hardware flow table. Stats lost for 128159929 packets. - The below mentioned actions have been carried out, but still the issue persists.
- Netflow has been disabled from global config mode and enabled on the required interfaces
- Flow aggregation and flow/cache timeouts have been enabled
- Not seeing any bug which can generate these log messages
- Show platform hardware netflow statistics utilization output shows - Total Used 8192 (100.0% - Bucket Count)
131017 ( 99.9% - Used Entry Count)
Please let me know the root cause behind this log message. Is there any way to suppress the generation of this log?
Best Regards,
Mike
10-17-2010 02:52 AM
sounds like the netflow table is overflowing . Sounds like you need to adjust how often it is throwing out idle flows . Adjust the timers so that they are shorter. Don't know of a way to keep them out of the logs..
05-17-2011 08:32 AM
| Breaks up long-lived flows into 1-minute fragments. You can choose any number of minutes between 1 and 60. If you leave it at the default of 30 minutes your traffic reports will have spikes. It is important to set this value to 1 minute in order to generate alerts and view troubleshooting data. |
ip flow-cache timeout inactive 15 | Ensures that flows that have finished are periodically exported. The default value is 15 seconds. You can choose any number of seconds between 10 and 600. However, if you choose a value greater than 250 seconds, NetFlow Analyzer may report traffic levels that are too low. |
Check these values.
Rick
