03-29-2012 09:33 AM - edited 03-07-2019 05:51 AM
need help to upgrade ios in cisco 4948 switch, I do not have admin right and network access
04-02-2012 01:59 PM
Still not working any suggestion!
04-02-2012 02:50 PM
In your new 4948, can you please post the command "dir flash:"?
04-02-2012 03:03 PM
Hi leolaohoo<>,>
Switch#dir bootflash:
Directory of bootflash:/
1 -rwx 17338692 Mar 30 2012 14:56:48 +00:00 10.1.1.2
60817408 bytes total (43478588 bytes free)
04-02-2012 03:16 PM
I believe you've renamed your IOS to "10.1.1.2".
04-02-2012 03:18 PM
No that is the ip address for the switch!
04-02-2012 03:26 PM
No it is not.
The so-called "IP address for the switch" has a FILE SIZE OF "17338692". You have renamed your IOS to "10.1.1.2".
04-02-2012 03:31 PM
leolaohoo<>,<>>>
How I am going to change the file name would you show me step by step!
04-02-2012 04:15 PM
Command: rename bootflash:10.1.1.2 bootflash:IOS_filename.bin
