Community Member
Cisco 500 Switch not allowing more than one port from a small Linksys
I just replaced my main switches with Cisco CE500. On those I branched out couple of 5 port Linksys switches.
Now only one device attached to the linksys is on the network out of four.
Is there a setting that I need to change?
The Linksys is plugged in a switch port by the way.
Thanks.
Community Member
Re: Cisco 500 Switch not allowing more than one port from a smal
Do not use smart port roles for the linksys ports, because the linksys switches probably don't support 802.1q trunking which in the switch role it enables.
Community Member
I changed the role for the port to other and that did it.
Thanks.
240
