Cisco 5000 series problems.
Hello. Im having troubles with my cisco 5000. I just got it used, and it freezes.
I hyperterminal in, using the settings Cisco reccomended.
ATE0
ATS0=1
ROM Power Up Diagnostics of Apr 20 1999
Init NVRAM Log
LED Test.......done
ROM Checksum...passed
Dual Port RAM r/w Test..passed
ID PROM...passed
System DRAM Size(mb)...32
DRAM Data Bus Test...passed
DRAM Address Test...passed
DRAM Byte/Work Access Test..passed
uncompressing nmp image
This will take a minute...
NMP image is successfully uncompressed in DRAM
then it freezes.
Any idea's?
//Edit//
http://www.rancidnebula.com/cisco.jpg
It did something new. After NMP image is successfully uncompressed in DRAM
it shows
Re: Cisco 5000 series problems.
Anyone?
Purple
Are you sure you are waiting long enough , these ancient Cat 5000's take a long time to boot and appear to freeze at times . Let it boot for 10 minutes and see if it completes .
Ok Ill try waiting longer. I assume you have never heard of this problem then.
I figured out the problem. the supervisor module was messed up. I replaced it with a different supervisor module and it works fine now.
126
