06-30-2014 09:09 PM - edited 03-07-2019 07:52 PM
Hi guys,
I need your suggestion on my following issue:
I have configure the ACL entries on my cisco 6500 series box but I see the ACL entries showing incorrect order when I check for the same.
Eg:
Europebox#show access-list 50
10 permit 192.50.20.2 (10 matches)
15 permit 192.52.0.134 (98 matches)
75 permit 198.29.232.23 (38 matches)
80 permit 10.96.127.14
90 permit 192.22.2.10
40 permit 192.22.0.76
anyhelp would be appriciated
regards
neha
Solved! Go to Solution.
07-01-2014 12:42 AM
Hi neha,
This is the expected behaviour that you see for the standard access-lists.
Inayath
07-01-2014 12:27 PM
Do a config t, then
Ip access-list resequence 50 10 10
Then look again
07-01-2014 12:42 AM
Hi neha,
Inayath
07-01-2014 12:27 PM
Do a config t, then
Then look again
