Community Member
Cisco 6500 --ACL entries showing incorrect order.
Hi guys,
I need your suggestion on my following issue:
I have configure the ACL entries on my cisco 6500 series box but I see the ACL entries showing incorrect order when I check for the same.
Eg:
Europebox#show access-list 50
10 permit 192.50.20.2 (10 matches)
 15 permit 192.52.0.134 (98 matches)
 75 permit 198.29.232.23 (38 matches)
 80 permit 10.96.127.14
 90 permit 192.22.2.10
 40 permit 192.22.0.76
anyhelp would be appriciated
regards
neha
2 ACCEPTED SOLUTIONS
Hi neha,This is the expected
Hi neha,
This is the expected behaviour that you see for the standard access-lists.
Inayath
Community Member
Go into your access list and
Do a config t, then
Ip access-list resequence 50 10 10
Then look again
Hi neha,
Inayath
Community Member
Do a config t, then
Then look again
49
