Cisco 6500 - LACP traffic
I have a circuit between two 6500 switches, its 100BaseT at the customer end and Etherchannel inbetween.  The 100BaseT ports are configured with dot1q-tunnel.  The customer is sending LACP traffic, they are stating we are blocking LACP traffic.  Can this be true, on Layer2 circuit, we are blocking this type of traffic?  Pls advise.
-Mn
1 ACCEPTED SOLUTION
Bronze
Re: Cisco 6500 - LACP traffic
This should work without issue.  Take a look at the 802.1q tunneling configuration guide, it shows LACP as supported:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/dot1qtnl.html
I don't believe it's supported with "l2protocol-tunnel", since LACP is a layer-1 protocol.
Hi ,
as far as i know it's not supported , try no negotiation etherchannel= mode on .
Dan
Bronze
Thnks Danrya, I will enable "l2protocol-tunnel point-to-point" on the 100BaseT  customer ports and not on the Fiber trunk connecting both 6500's.  This will enable LACP, PAGP and UDLD.
-Mn
540
