Community Member
Cisco 6500 Power Supply Installation
Hi,everybody
I've got a 6509E with two 3000W power supplys. I need to change one of them for a 6000w, i want to know if there is some problem if the sw works with differents powers supplys and which can be the configuration (CLI) in this case.
Thanks in advance for your help
Community Member
Re: Cisco 6500 Power Supply Installation
hello ,
can you post your engine parameter ?   usually that have nothing to change.
Community Member
Engine parameter? i dont know what is that
Can you explain?
Is necessary any command to configure this power supply correctly?
400
