Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Cisco 6500 series switch IOS upgrade
Can anyone discuss or forward the procedure for upgrading the IOS for Cisco 6500 series switch.
Logesh
Re: Cisco 6500 series switch IOS upgrade
What is the current OS running on your 65K switch.is that CatOS or IOS ??
Can you paste the output of the below command from your 65K switch
#sh version
Based on the output sh version, i can suggest the procedure to upgrade the IOS
Samy
hi
please below is the sh ver result
Cisco IOS Software, s3223_rp Software (s3223_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 27-Mar-09 11:40 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
Swich uptime is 1 year, 5 weeks, 3 days, 4 hours, 30 minutes
Uptime for this control processor is 1 year, 5 weeks, 3 days, 3 hours, 55 minutes
Time since Swich switched to active is 1 year, 5 weeks, 3 days, 3 hours, 52 minutes
System returned to ROM by power on at 21:05:33 UTC Wed Jul 15 2009 (SP by power on)
System restarted at 00:39:45 UTC Thu Jul 16 2009
System image file is "sup-bootdisk:s3223-adventerprisek9_wan-mz.122-33.SXI1.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-V-E (R7000) processor (revision 1.0) with 458752K/65536K bytes of memory.
Processor board ID ----------
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
6 Virtual Ethernet interfaces
210 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Hall of Fame Super Gold
1.  Copy the IOS into the sup-bootflash:.  You can either use a TFTP server or copy the IOS from your PC to a CF and from the CF to the sup-bootflash:.
2.  Change the boot variable parameter.
3.  Save the config and reload.
Thanks for the help everything went on well.
What is the prcedure to upgrade the code if it is a CatOS           software
Is the process different
regards
Logesh
834
