11-03-2013 08:59 AM - edited 03-07-2019 04:24 PM
I have a new Cisco 6506-E chassis with VS-SUP720 3C and am trying to get it onto Adv IP Services SXJ6. When setting the bootvar to either disk0 or bootdisk (to try and rule out media issues) I get:
Self extracting the image... [OK]
*** TLB (Load/Fetch) Exception ***
Access address = 0x88a7e02
PC = 0x8800001c, Cause = 0x8, Status Reg = 0x30409003
monitor: command "boot" aborted due to exception
Exit at the end of BOOT string
And the box drops into rommon.
Running SXI8a is fine from any media.
I have formatted the flash and re-uploaded the image again and still no luck.
Does anyone have any ideas?
Paul
11-03-2013 10:01 AM
Try downloading the image from Cisco's site again and test. If that does not help, how about a different image in the SXJx series?
11-03-2013 10:24 AM
Do you think its likely to be the software image?
Its a slightly complicated situation in that we bought the software from Cisco when we ordered the hardware so I have two CDs with SXJ6 on (both have the same issue). Unfortatly we don't have a support contact directly with Cisco so I'm unable to download either the same or different image from the support site.
11-03-2013 10:31 AM
Hi Paul,
It is hard to tell. I am just trying to eliminate another possibility, but if you don't have SmartNet contract, you can't download any other image. Here is another thing you can try. Open a ticket with TAC and explain the situation and see if they let you download a different version or the same one.
11-07-2013 01:13 PM
Ended up needing to upgrade the bootloader on the sups which seemed to fix it.
