Cisco 6500 VSS Dram Error
CSCO11177789
Hello;
Since yesterday, i see
Nov 16 13:23:21.355: %SYSTEM_CONTROLLER-3-MORE_COR_ERR:  255 correctable DRAM memory errors in previous hour
Nov 16 13:23:21.355: %SYSTEM_CONTROLLER-3-COR_MEM_ERR: Correctable DRAM memory error. Count 623, log 8053C830
Nov 16 14:23:21.340: %SYSTEM_CONTROLLER-3-MORE_COR_ERR:  255 correctable DRAM memory errors in previous hour
Nov 16 14:23:21.340: %SYSTEM_CONTROLLER-3-COR_MEM_ERR: Correctable DRAM memory error. Count 879, log 8053C810
error on switch console every hour.
ios version :
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXJ1, RELEASE SOFTWARE (fc2)
what do you suggest ?
Thanks, best regards
Reza Sharifi
This might be memory or Sup issue
SYSTEM_CONTROLLER-3
Error Message    %SYSTEM_CONTROLLER-3-COR_MEM_ERR: Correctable DRAM memory error. Count [dec], log [hex]
Explanation    A transient DRAM memory error was detected and corrected.
Recommended Action    If the error message appears infrequently, no action is required. If the message  recurs, reseat the SDRAM SIMM on the supervisor engine. If errors persist, replace the SIMM. If  the errors continue after the SIMM is replaced, the supervisor engine may need to be replaced.
http://www.cisco.com/en/US/docs/ios/12_2sx/system/messages/sm2sx09.html#wp1013864
Thank you for your fast and useful response.
Best regards
let me ask one more question;
How could i know which sups ram has an error ? Is it on active sup ?  I've 4 sup on two chasis.
Best regards
It would have to be the active Sup, because the stand-by is not managing the chassis until the primary goes down.
