Community Member
Cisco 6500 VSS power supply question
Hello everyone!
I have a question about the possible outcome or behaviour of the power managmet during a power supply failure on a 6500 VSS.
Our costumer core switches consisting of two 6509-E in a VSS.
Here is the output of Show Enviroment and Show power switch all commands from the VSS:
------------------ show environment ------------------
environmental alarms:
  no alarms
switch 1 backplane:
  operating clock count: 2
  operating VTT count: 3
  operating fan count: 1
switch 2 backplane:
switch 1 fan-tray 1:
  switch 1 fan-tray 1 type: WS-C6509-E-FAN
  switch 1 fan-tray 1 mode: High-power
  switch 1 fan-tray 1 fan-fail: OK
switch 2 fan-tray 1:
  switch 2 fan-tray 1 type: WS-C6509-E-FAN
  switch 2 fan-tray 1 mode: High-power
  switch 2 fan-tray 1 fan-fail: OK
switch 1 VTT 1:
  switch 1 VTT 1 OK: OK
  switch 1 VTT 1 outlet temperature: 30C
switch 1 VTT 2:
  switch 1 VTT 2 OK: OK
  switch 1 VTT 2 outlet temperature: 28C
switch 1 VTT 3:
  switch 1 VTT 3 OK: OK
  switch 1 VTT 3 outlet temperature: 26C
switch 2 VTT 1:
  switch 2 VTT 1 OK: OK
  switch 2 VTT 1 outlet temperature: 28C
switch 2 VTT 2:
  switch 2 VTT 2 OK: OK
  switch 2 VTT 2 outlet temperature: 28C
switch 2 VTT 3:
  switch 2 VTT 3 OK: OK
  switch 2 VTT 3 outlet temperature: 37C
VTT 10:
  VTT 10: not available
VTT 11:
  VTT 11: not available
VTT 12:
  VTT 12: not available
switch 1 clock 1:
  switch 1 clock 1 OK: OK, switch 1 clock 1 clock-inuse: in-use
switch 1 clock 2:
  switch 1 clock 2 OK: OK, switch 1 clock 2 clock-inuse: not-in-use
switch 2 clock 1:
  switch 2 clock 1 OK: OK, switch 2 clock 1 clock-inuse: in-use
switch 2 clock 2:
  switch 2 clock 2 OK: OK, switch 2 clock 2 clock-inuse: not-in-use
switch 1 power-supply 1:
  switch 1 power-supply 1 fan-fail: OK
  switch 1 power-supply 1 power-input: AC low
  switch 1 power-supply 1 power-output-mode: low
  switch 1 power-supply 1 power-output-fail: OK
switch 1 power-supply 2:
  switch 1 power-supply 2 fan-fail: OK
  switch 1 power-supply 2 power-input: AC low
  switch 1 power-supply 2 power-output-mode: low
  switch 1 power-supply 2 power-output-fail: OK
switch 2 power-supply 1:
  switch 2 power-supply 1 fan-fail: OK
  switch 2 power-supply 1 power-input: AC high
  switch 2 power-supply 1 power-output-mode: high
  switch 2 power-supply 1 power-output-fail: OK
switch 2 power-supply 2:
  switch 2 power-supply 2 fan-fail: OK
  switch 2 power-supply 2 power-input: AC high
  switch 2 power-supply 2 power-output-mode: high
  switch 2 power-supply 2 power-output-fail: OK
switch 1 module 1:
  switch 1 module 1 power-output-fail: OK
  switch 1 module 1 outlet temperature: 45C
  switch 1 module 1 inlet temperature: 24C
  switch 1 module 1 device-1 temperature: 25C
  switch 1 module 1 device-2 temperature: 41C
switch 1 module 2:
  switch 1 module 2 power-output-fail: OK
  switch 1 module 2 outlet temperature: 40C
  switch 1 module 2 inlet temperature: 25C
switch 1 module 3:
  switch 1 module 3 power-output-fail: OK
  switch 1 module 3 outlet temperature: 40C
  switch 1 module 3 inlet temperature: 25C
  switch 1 module 3 device-1 temperature: 26C
  switch 1 module 3 device-2 temperature: 37C
switch 1 module 4:
  switch 1 module 4 power-output-fail: OK
  switch 1 module 4 outlet temperature: 46C
  switch 1 module 4 inlet temperature: 33C
  switch 1 module 4 asic-13 temperature: 66C
  switch 1 module 4 asic-14 temperature: 68C
  switch 1 module 4 EARL outlet temperature: 37C
  switch 1 module 4 EARL inlet temperature: 29C
  switch 1 module 4 EARL device-2 temperature: 48C
switch 1 module 5:
  switch 1 module 5 power-output-fail: OK
  switch 1 module 5 outlet temperature: 40C
  switch 1 module 5 inlet temperature: 25C
  switch 1 module 5 device-1 temperature: 33C
  switch 1 module 5 device-2 temperature: 36C
  switch 1 module 5 asic-1 temperature: 62C
  switch 1 module 5 asic-2 temperature: 42C
  switch 1 module 5 asic-4 temperature: 60C
  switch 1 module 5 asic-5 temperature: 48C
  switch 1 module 5 asic-7 temperature: 48C
  switch 1 module 5 asic-8 temperature: 65C
  switch 1 module 5 RP outlet temperature: 36C
  switch 1 module 5 RP inlet temperature: 32C
  switch 1 module 5 RP device-1 temperature: 46C
  switch 1 module 5 EARL outlet temperature: 35C
  switch 1 module 5 EARL inlet temperature: 27C
  switch 1 module 5 EARL device-1 temperature: 45C
  switch 1 module 5 EARL device-2 temperature: 46C
switch 2 module 1:
  switch 2 module 1 power-output-fail: OK
  switch 2 module 1 outlet temperature: 59C
  switch 2 module 1 inlet temperature: 29C
  switch 2 module 1 device-1 temperature: 29C
  switch 2 module 1 device-2 temperature: 53C
switch 2 module 2:
  switch 2 module 2 power-output-fail: OK
  switch 2 module 2 outlet temperature: 46C
  switch 2 module 2 inlet temperature: 27C
switch 2 module 3:
  switch 2 module 3 power-output-fail: OK
  switch 2 module 3 outlet temperature: 49C
  switch 2 module 3 inlet temperature: 28C
  switch 2 module 3 device-1 temperature: 29C
  switch 2 module 3 device-2 temperature: 44C
switch 2 module 4:
  switch 2 module 4 power-output-fail: OK
  switch 2 module 4 outlet temperature: 52C
  switch 2 module 4 inlet temperature: 35C
  switch 2 module 4 asic-13 temperature: 75C
  switch 2 module 4 asic-14 temperature: 77C
  switch 2 module 4 EARL outlet temperature: 42C
  switch 2 module 4 EARL inlet temperature: 30C
  switch 2 module 4 EARL device-2 temperature: 50C
switch 2 module 5:
  switch 2 module 5 power-output-fail: OK
  switch 2 module 5 outlet temperature: 40C
  switch 2 module 5 inlet temperature: 27C
  switch 2 module 5 device-1 temperature: 33C
  switch 2 module 5 device-2 temperature: 37C
  switch 2 module 5 asic-1 temperature: 65C
  switch 2 module 5 asic-2 temperature: 44C
  switch 2 module 5 asic-4 temperature: 61C
  switch 2 module 5 asic-5 temperature: 47C
  switch 2 module 5 asic-7 temperature: 47C
  switch 2 module 5 asic-8 temperature: 70C
  switch 2 module 5 RP outlet temperature: 36C
  switch 2 module 5 RP inlet temperature: 33C
  switch 2 module 5 RP device-1 temperature: 48C
  switch 2 module 5 EARL outlet temperature: 36C
  switch 2 module 5 EARL inlet temperature: 27C
  switch 2 module 5 EARL device-1 temperature: 47C
  switch 2 module 5 EARL device-2 temperature: 47C
  chassis connector rating: 1302.00 Watts (31.00 Amps @ 42V)
switch 2 module 1
  switch 2 module 1 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  switch 2 module 1 power consumption:  254.94 Watts ( 6.07 Amps @ 42V)
switch 2 module 2
  switch 2 module 2 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  switch 2 module 2 power consumption:  325.50 Watts ( 7.75 Amps @ 42V)
switch 2 module 3
  switch 2 module 3 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  switch 2 module 3 power consumption:  254.94 Watts ( 6.07 Amps @ 42V)
switch 2 module 4
  switch 2 module 4 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  switch 2 module 4 power consumption:  588.00 Watts (14.00 Amps @ 42V)
switch 2 module 5
  switch 2 module 5 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  switch 2 module 5 power consumption:  435.54 Watts (10.37 Amps @ 42V)
chassis per slot cooling capacity: 94 cfm
ambient temperature: < 55C
  switch 1 module 1 cooling requirement: 70 cfm
  switch 1 module 2 cooling requirement: 70 cfm
  switch 1 module 3 cooling requirement: 70 cfm
  switch 1 module 4 cooling requirement: 84 cfm
  switch 1 module 5 cooling requirement: 84 cfm
  switch 2 module 1 cooling requirement: 70 cfm
  switch 2 module 2 cooling requirement: 70 cfm
  switch 2 module 3 cooling requirement: 70 cfm
  switch 2 module 4 cooling requirement: 84 cfm
  switch 2 module 5 cooling requirement: 84 cfm
------------------ show power switch all ------------------
Switch Number: 1
system power redundancy mode = redundant
system power total =     2671.20 Watts (63.60 Amps @ 42V)
system power used =      2504.46 Watts (59.63 Amps @ 42V)
system power available =  166.74 Watts ( 3.97 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-6000W       2671.20 63.60  OK     OK     on
2    WS-CAC-6000W       2671.20 63.60  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6509-E-FAN      210.00  5.00  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6748-SFP        254.94  6.07   254.94  6.07  on    on
2    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
3    WS-X6748-SFP        254.94  6.07   254.94  6.07  on    on
4    WS-X6908-10G        588.00 14.00   588.00 14.00  on    on
5    VS-SUP2T-10G        435.54 10.37   435.54 10.37  on    on
6    (Redundant Sup)       -     -      435.54 10.37  -     -
Switch Number: 2
system power total =     2771.16 Watts (65.98 Amps @ 42V)
system power available =  266.70 Watts ( 6.35 Amps @ 42V)
1    WS-CAC-3000W       2771.16 65.98  OK     OK     on
2    WS-CAC-3000W       2771.16 65.98  OK     OK     on
                        Pwr-Allocated  Oper
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   10920.00 Watts (260.00 Amps @ 42V)
system auxiliary connector power limit = 10500.00 Watts (250.00 Amps @ 42V)
system primary power used =              2504.46 Watts (59.63 Amps @ 42V)
system auxiliary power used =            0 Watt
Our question is, what is expected to happen if for example, PS1 on SWITCH 1 (WS-CAC-6000W) fails. Is it a possible scenario that under the current configuration, that the other redundant PS2 on SWITCH1 will fail to deliver enough power to the modules on the the switch, causing a failover?
Thanks in advance,
Daniel
Everyone's tags (3)
Daniel,
I have not tested this but yes it should fail to bring most of the modules.
Redundant Mode:
When running in Redundant Mode, each power supply provides approximately 50% of its capacity to the chassis. In the event of a failure, the unaffected power supply will then provide 100% of its capacity and an alert will be generated. As there was enough to power the chassis ahead of time, there is no interruption to service in this configuration. This is also the default and recommended way to configure power supplies
Inayath
Community Member
Hello Inayath, thank you for the quick response.
So if I understand correctly, if we look at the power supply on Switch 1:
Switch Number: 1
                        Pwr-Allocated  Oper
Switch 1 is using 2504.46W from both 6000W supplies, and if one of the them fails, it will still use 2504.46W from on 6000W power supply. Is this correct?
Switch 2 is also consuming the same amount of power like Switch 1 due to the same modules, but using two 3000W PS's. What are the chances for failure in this case?
955
