04-19-2012 04:29 AM - edited 03-07-2019 06:13 AM
Hi.
I have a 6509-E with the VS-S720-10G and the IOS version is 12.2(33)SXH5, and I will possibly buy the WS-X6708-10GE module. I already read the documentation, and i think i don't have any problem to install this module in my chassi. I'm forgetting something?
Solved! Go to Solution.
04-19-2012 04:45 AM
Should not be any issue at all. Don't forget to buy the X2 modules for the blade. Regarding your IOS, you may want to upgrade to an SXI series instead of SXH. Cisco has deployed more features to SXI than SXH. There is also SXJ, which is the latest.
04-19-2012 04:45 AM
04-22-2012 07:06 AM
Thanks Reza
About IOS I need to see a new support contract to access the IOS and upgrade
04-22-2012 07:20 AM
As long as you have an existing valid service contract, you can download SXI.
Reza
