Cisco 6509-E and AAA
The following is the existing AAA config on my 6509 switch:
aaa new-model
aaa authentication login default group tacacs+
aaa authentication enable default group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
This works except for the fact that when enable command is issued, it prompts for username again after the initial username. See below:
User Access Verification
Username: xxxxxxx
Password:
6509>en
Username: xxxxxxxx
Password:
6509#
Does anyone know what may be causing this and how it can be solved.
8 Replies 8
davy.timmermans
Level 4
Level 4
no aaa authentication enable default group tacacs+
A default authentication is defined for enable which overrides the enable secret
I have apllied the following:
See what I have:
Username: xxxxxx
Password:
6509>en
Password:
% Access denied
I still want to use tacacs+ for my priviledge password for the enable command. This is the way it works for all other devices (routers and switches) on my network except the newly deployed 6509-E
Could this be an issue with 6509?
Many thanks for your help.
I just got this from cisco documentation:
CSCsu21040 -- AAA Enable authentication prompts for username/password instead of just password
The caveats was solved in Release 12.2(33)SXH4
Hello Stephen,
with the following config it works well for us
sh run | inc aaa
aaa new-model
aaa authentication login ACS group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa accounting update newinfo
aaa accounting exec ACS start-stop group tacacs+
aaa accounting commands 1 ACS start-stop group tacacs+
aaa accounting commands 15 ACS start-stop group tacacs+
aaa session-id common
sh ver | inc image
System image file is "disk0:s72033-advipservicesk9_wan-mz.122-33.SXH2.bin"
Hope to help
Giuseppe
This is similar to my config:
The only differenet here is that you used the word option - ACS instead of using default and in your case applied login authentication ACS under line vty 0 15.
It is interesting though that you said it is working for you without bringing the second username --- which is the main issue here.
This is caused by the bug CSCsu21040. From Cisco documentation, the description given to the bug is AAA Enable authentication prompts for username/password instead of just password. This caveats was solved in release 12.2(33) SXH4
Search for CSCsu21040 from:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.pdf
Confirmed
Hello Stephen,
I see in the list of affected versions that also our release should be affected.
Probably some of our additional commands like
are a workaround for this
yes the method list is ACS and it is applied on the vty
sh run | beg line vty
line vty 0 3
access-class 24 in
exec-timeout 15 0
password 7
accounting exec ACS
transport input lat pad udptn telnet rlogin ssh acercon
Hope to help
Giuseppe
