Community Member
Cisco 6509 High CPU Load
hi,
I recently replaced a Cisco 7606 with a Cisco 6509. The same configs on the Cisco 7606 were moved to the Cisco 6509 and the same supervisor engine type was used.
it was noticed that the Cisco 6509 remained at 100% after the installation.
This has raised a lot of concern.
Please see attached sh command output for more info.
1 REPLY
Re: Cisco 6509 High CPU Load
under show proc cpu detailed under "ios-base" and "iprouting.iosproc" what do you see? there should be other process that will tell you which process in particular contributes to high utilization to ios-base and iprouting. Also, check your log, see if there are any logs that might be related to high cpu.
414
