Cisco 6509 : Port ERR_DISABLE
Rosa Ladeira
I have a printer on port 7/25.
7   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-45AF  SAD091000F0
working together with supervisor
5    9  Supervisor Engine 32 8GE (Active)      WS-SUP32-GE-3B     SAL1204DWQJ
I have got the error above :
Sep 13 10:56:22 severi-outside 9941301: 16w0d: %CONST_DIAG-SP-3-HM_PORT_ERR: Port 25 on module 7 failed 10 consecutive times. Disabling the port.
Sep 13 10:56:22 severi-outside 9941303: 16w0d: %PM-SP-4-ERR_DISABLE: diagnostics error detected on Gi7/25, putting Gi7/25 in err-disable state
Severi#show interfaces status err-disabled module 7
Port    Name               Status       Reason
Gi7/25  *** Ponto 21.254 - err-disabled diagnostics
Severi#
Severi#show interfaces gigabitEthernet 7/25
GigabitEthernet7/25 is down, line protocol is down (err-disabled)
  Hardware is C6k 1000Mb 802.3, address is 0013.7f2d.2288 (bia 0013.7f2d.2288)
  Description: *** Ponto 21.254 - Sala 200A ***
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed
  input flow-control is off, output flow-control is desired
  Clock mode is auto
  Last input never, output 1d17h, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 2962
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     397873 packets input, 34243387 bytes, 0 no buffer
     Received 168568 broadcasts (166767 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     26082168 packets output, 6171096605 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
Severi#show errdisable detect
ErrDisable Reason    Detection status
udld                 Enabled
bpduguard            Enabled
security-violatio    Enabled
channel-misconfig    Enabled
psecure-violation    Enabled
mac-limit            Enabled
unicast-flood        Enabled
pagp-flap            Enabled
dtp-flap             Enabled
link-flap            Enabled
l2ptguard            Enabled
gbic-invalid         Enabled
dhcp-rate-limit      Enabled
arp-inspection       Enabled
inline-power         Enabled
packet-buffer        Enabled
transceiver-incom    Enabled
Does anybody know what is this ?
Thanks in advance.
Rosa
Hello Rosa,
I can only say that the test results confirm the port is considered not working correctly.
However, try to connect to the port a different device or even to leave the port unplugged and remake the test.
Hope to help
Giuseppe
9 Replies 9
Giuseppe Larosa
Hello Rosa,
I'm afraid it can be an hardware issue
Hope to help
Giuseppe
Hi Giuseppe,
what should I do to be sure it is hardware error ?
Rosa
Dear Giuseppe,
I had already done this all.
I did all again just in case:
Severi#show log | inc 7/25
Severi#
Severi#
Severi#
Severi#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Severi(config)#interf
Severi(config)#interface g7/25
Severi(config-if)#shut
...... 5 minutes
Severi(config-if)#no shut
Severi(config-if)#^Z
Severi#
Severi#
Severi#
Severi#show interf
Severi#show interfaces g7/25
     reliability 255/255, txload 0/255, rxload 0/255
  Clock mode is auto
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 3019
     0 output errors, 0 collisions, 6 interface resets
Severi#
On my private logs:
[netadm@muller routers]$ grep "7/25" severi.log
Sep 13 15:40:06 severi-outside 9958274: 16w1d: %PM-SP-4-ERR_DISABLE: diagnostics error detected on Gi7/25, putting Gi7/25 in err-disable state
Rosa
Does anyone know what is NonDisruptiveLoopback ?
Severi#show diagnostic result module 7 test all detail
Current bootup diagnostic level: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
  ___________________________________________________________________________
    1) TestScratchRegister -------------> .
          Error code ------------------> 0 (DIAG_SUCCESS)
          Total run count -------------> 329060
          Last test execution time ----> Sep 15 2010 13:41:49
          First test failure time -----> n/a
          Last test failure time ------> n/a
          Last test pass time ---------> Sep 15 2010 13:41:49
          Total failure count ---------> 0
          Consecutive failure count ---> 0
    2) TestNonDisruptiveLoopback:
   Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
   Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
         F  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .
          Total run count -------------> 1778464
          Last test execution time ----> Sep 15 2010 13:42:07
          First test failure time -----> Sep 11 2010 23:18:25
          Last test failure time ------> Sep 11 2010 23:25:53
          Last test pass time ---------> Sep 15 2010 13:42:07
          Total failure count ---------> 10
    3) TestLoopback:
          Last test execution time ----> May 23 2010 12:00:55
          Last test pass time ---------> May 23 2010 12:00:55
    4) TestNetflowInlineRewrite:
         U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U
          Total run count -------------> 0
          Last test execution time ----> n/a
          Last test pass time ---------> n/a
    5) TestAsicMemory ------------------> U
    6) TestEobcStressPing --------------> U
    7) TestFirmwareDiagStatus ----------> .
          Last test execution time ----> May 23 2010 12:01:05
          Last test pass time ---------> May 23 2010 12:01:05
    8) TestVDB -------------------------> .
Severi# Connection closed by foreign host.
Hello Rosa,
Hope to help
Giuseppe
Thanks Giuseppe, once again, for your help.
You were rigth from the begining.
I have done those other tests you have suggested and got the same result: null.
It is a pity.
att,
Rosa
nul
L2-TFR-PFR-VSS#show interfaces status err-disabled
Te2/1/21 err-disabled diagnostics
Note: err-disable during the HM test. Need more clarification this, any one help
Balaji K
The TestNonDisruptiveLoopback test verifies the data path between the
supervisor engine and the network ports of a module. In this test, a Layer 2
packet is flooded onto VLAN that contains a group of test ports. The test
port group consists of one port per port ASIC channel. Each port in the test
port group nondisruptively loops back the packet and directs it back to the
supervisor engine's inband port. The ports in the test port group are tested
in parallel.
Based on the above, the error is telling us that a loopback packet went
missing somewhere in the path from supervisor to  line card port
asic and back.
