CISCO 6509 VLANS
par13
I have created three vlans
VLAN 100
VLAN 200
VLAN 300
The cisco 3550 are configure with each respective vlan 100, 200, and 300.
As soon as I plug the switch on the fiber module, I notices the switch been added to the proper VLAN. I have execute the command sh vlan 100, and it shows the switches configure for vlan 100. The same thing for vlan 200 and 300.
However, I notices some switches were added to the wrong vlans. Is there a command or configuration that I am doing that is causing this issue?
97 Replies 97
Jerry Ye
Hi Pedro,
What do you mean by "some switches were added to the wrong vlans"?
What is your topology? And what VTP mode are you using on all the switches?
jerry
Yes, the vlans are configure as this:
VLAN 100 172.31.181.128/26
VLAN 200 172.31.181.192/26
VLAN 300 172.31.13.0/24
Each switch,from the different networks, connect to the core router thru fiber connection.
I have been creating the vlans on the
cisco switches using the script. Follow, I have included a sample configuration for each of the vlan configuration (VLAN 100, 200, and 300)
VLAN 100
ip domain-name lv.psu.edu
ip ssh version 2
int range f0/1 - 24
description academic
switchport access vlan 100
switchport mode access
interface GigabitEthernet0/1
description Trunk to Cisco6509 router
switchport mode trunk
no shut
interface GigabitEthernet0/2
switchport mode dynamic desirable
interface Vlan1
ip address 172.31.181.194 255.255.255.192
no shut
interface Vlan100
description Academic
no ip address
no ip route-cache
no shut
VLAN 200
ip ssh version 2
int range f0/1 - 24
description Administrative
switchport access vlan 200
no shut
interface Vlan1
no shut
interface Vlan200
ip address 172.31.181.130 255.255.255.192
no shut
ip classless
ip http server
ip http secure-server
VLAN 300
ip ssh version 2
int range f0/1 - 24
description Wireless
switchport access vlan 300
no shut
no shut
no shut
interface Vlan1
ip address 172.31.13.3 255.255.255.0
no shut
interface Vlan300
no ip address
no ip route-cache
no shut
ip classless
But, I'm not sure if it would work better to use vtp at each switch, or after configuring vtp server on cisco 6509, every switch will self join the appropiate vlan.
Hi Pedro,
I see that you are using Vlan 1 for management and not going configure IP addresses on interface Vlan100, Vlan200, and Vlan300. If this is the case, there is not need for interface Vlan100, etc on these switches.
So which switch is getting the wrong Vlan? Which command give you that impression, can you post the output of that also? Also, if you would post the output of the following three (3) commands on all the 3550's and the 6500's, it will be great:
show vtp status
show vlan
show int trunk
jerry
Jerry,
I will be doing this as soon as I get to work this morning.
1) DO you recommend using Manual VLAN script or creating them on each switch VTP Database?
2) As far switch vlan adding themselves to VLANS on CISCO 6509, when running the command sh vlan 100, it shows the vlan number and on the right hand, a list of fiber ports that I'm assumming are switches with pre-configure vlans.
Is this assumption correct?
Hi Pedro,
It is upto you which method you prefer, as long as they are correct.
From you description of the output, sound like the ports are assigned to the VLAN someone configured before. The only pre-configurated VLAN is really VLAN1 where it cannot be deleted.
HTH,
jerry
Jerry,
As you can see, I am including the information you have requested.
One issue we are having with the cisco 6509, the vlan are been set to native vlan 1. However, the switches are configured with 100,200 and 300, respectively.
How can I set on cisco 6509 to put this vlan 100,200 and 300 in the correct native vlan, instead of cisco deciding to pu them on native vlan 1?
CISCO 6509 --- Server
Console> (enable) sh vtp domain
Domain Name Domain Index VTP Version Local Mode
Password
lv.psu.edu 1 2 server -
Vlan-count Max-vlan-storage Config Revision Notifications
8 1023 0 disabled
Last Updater V2 Mode Pruning PruneEligible on Vlans
0.0.0.0 disabled disabled 2-1000
Console> (enable) sh vtp statistics
VTP statistics:
summary advts received 109
subset advts received 58
request advts received 0
summary advts transmitted 1320
subset advts transmitted 200
request advts transmitted 51
No of config revision errors 0
No of config digest errors 51
VTP pruning statistics:
Trunk Join Transmitted Join Received Summary advts received from GVRP
PDU
non-pruning-capable device
Received
3/4 0 0 0 0
3/6 0 0 0 0
4/4 0 0 0 0
15/1 0 0 0 0
16/1 0 0 0 0
Console> (enable)
Console> (enable) sh vlan
VLAN Name Status IfIndex Mod/Ports, Vlans
1 default active 199 1/1-2
2/1-2
3/1-3
4/2-3,4/5-16
6/1-8,6/10,6/15-
48
7/1-32,7/34-48
100 academic active 205 3/5,3/7-16
200 admin active 204 7/33
300 wireless active 206 4/1
6/9,6/11-14
1002 fddi-default active 200
1003 token-ring-default active 203
1004 fddinet-default active 201
1005 trnet-default active 202
VLAN Type SAID MTU Parent RingNo BrdgNo Stp BrdgMode Trans1
Trans2
1 enet 100001 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
200 enet 100200 1500 - - - - - 0 0
300 enet 100300 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 trcrf 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - - - 0 0
1005 trbrf 101005 1500 - - - ibm - 0 0
VLAN MISTP-Inst DynCreated RSPAN
1 - static disabled
100 - static disabled
200 - static disabled
300 - static disabled
1002 - static disabled
1003 - static disabled
1004 - static disabled
1005 - static disabled
VLAN AREHops STEHops Backup CRF 1q VLAN
1003 7 7 off
Console> (enable)
CISCO 6509- Router
SRVRM-6509-MSFC1#sh run
Building configuration...
Current configuration : 3547 bytes
! Last configuration change at 08:52:47 EDT Thu Jul 9 2009
! NVRAM config last updated at 17:08:29 EDT Wed Jul 8 2009
version 12.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname SRVRM-6509-MSFC1
boot system bootflash:c6msfc2-psv-mz.121-13.E3.bin
boot bootldr bootflash:c6msfc2-boot-mz.121-13.E3.bin
no logging console
enable secret 5 $1$k3j8$vSFg2vXjmUMrtU/pxlCTX/
enable password 7 08121C430B0B0005424A
clock timezone EST -5
clock summer-time EDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
clock calendar-valid
ip subnet-zero
interface Loopback0
ip address 10.5.12.1 255.255.255.255
interface Vlan1
description Management VLAN
ip address 172.31.181.189 255.255.255.192
no ip redirects
standby 1 ip 172.31.181.129
standby 1 priority 120
standby 1 preempt
interface Vlan100
description Lab 214 VLAN
ip address 146.186.50.253 255.255.255.0
no ip redirects
standby 1 ip 146.186.50.1
standby 1 preempt
interface Vlan200
description LAB 200 VLAN
ip address 146.186.27.253 255.255.255.0
ip helper-address 146.186.27.3
no ip redirects
standby 1 ip 146.186.27.1
standby 1 preempt
interface Vlan300
description Wireless Lan
ip address 172.31.13.254 255.255.255.0
no ip redirects
standby 1 ip 172.31.13.1
standby 1 preempt
Console> (enable) sh vlan 1
2/1-2
3/1-3
4/2-16
6/1-8,6/10,6/15-48
7/1-32,7/34-48
15/1
16/1
VLAN Type SAID MTU Parent RingNo BrdgNo Stp BrdgMode Trans1 Trans2
1 - static disabled
Console> (enable) sh trunk
* - indicates vtp domain mismatch
Port Mode Encapsulation Status Native vlan
3/2 auto n-dot1q trunking 1
3/3 auto dot1q trunking 1
4/3 auto n-dot1q trunking 1
4/4 auto n-dot1q trunking 300
4/6 auto dot1q trunking 200
15/1 nonegotiate isl trunking 1
16/1 nonegotiate isl trunking 1
Port Vlans allowed on trunk
3/2 1-1005,1025-4094
3/3 1-1005,1025-4094
4/3 1-1005,1025-4094
4/4 1-1005,1025-4094
4/6 1-1005,1025-4094
15/1 1-1005,1025-4094
16/1 1-1005,1025-4094
Port Vlans allowed and active in management domain
CISCO 3550
___________________________________
Cisco 3550
LV-126B-AD-181-130#sh vtp
% Incomplete command.
LV-126B-AD-181-130#sh vtp st
LV-126B-AD-181-130#sh vtp status
VTP Version : 2
Configuration Revision : 10
Maximum VLANs supported locally : 1005
Number of existing VLANs : 8
VTP Operating Mode : Client
VTP Domain Name : lv.psu.edu
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0xD2 0xD9 0xE9 0xBA 0xA1 0x35 0xF7 0xBE
Configuration last modified by 172.31.13.4 at 3-1-93 00:07:39
LV-126B-AD-181-130#sh trunk
% Invalid input detected at '^' marker.
LV-126B-AD-181-130#sh vlan
VLAN Name Status Ports
1 default active Gi0/2
100 academic active
200 administrative active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10, Fa0/11, Fa0/12
Fa0/13, Fa0/14, Fa0/15, Fa0/16
Fa0/17, Fa0/18, Fa0/19, Fa0/20
Fa0/21, Fa0/22, Fa0/23, Fa0/24
300 wireless active
1002 fddi-default act/unsup
1003 trcrf-default act/unsup
1004 fddinet-default act/unsup
1005 trbrf-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1003 trcrf 101003 4472 1005 3276 - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trbrf 101005 4472 - - 15 ibm - 0 0
1003 0 0 off
Remote SPAN VLANs
Primary Secondary Type Ports
LV-126B-AD-181-130#sh int trunk
Gi0/1 on 802.1q trunking 200
Gi0/1 1-4094
Gi0/1 1,100,200,300
Port Vlans in spanning tree forwarding state and not pruned
Gi0/1 1,100,200,300
LV-126B-AD-181-130#
Hi Pedro,
This is my observation:
1) Your 6500 is running as VTP server, and you've configured SVI for Inter-VLAN routing
2) Your 3550's are running as VTP client and L2
When you have VTP clients and attaching them to the VTP server, VTP server will copy its VLAN database into the clients when the revision number of the server is higher than the clients. (Just a side note, when the client's revision number is higher than the server, it will override the server's VLAN database, be careful with this!!!).
So I am assuming your concern is you don't want, example, VLAN 100 and 300 apprear on your switch - LV-126B-AD-181-130's VLAN database? If this is the case, you have to make all the switches as VTP transparent mode and configure each VLAN manually, and prune them manually. There is another solution, you might want to consider, where you can turn on VTP pruning, just use the command set vtp prun on you VTP server, 6500's CatOS. It will prune the traffic out of the trunk link.
HTH,
jerry
Jerry,
How come the vlans are showing, on the server, as native vlan 1.
How can I change this information?
Hi Pedro,
That is the native VLAN for the trunk port, default is VLAN 1. You can change it by using set trunk x/x 100 where x/x is your port and 100 is your VLAN number. You have to change both side of the trunk to match, otherwise the switches will complain about native VLAN mismatch. You have to be careful when you are changing this, native VLAN mismatch can cause a spanning tree loop.
HTH,
jerry
can you send me a simple configuration for configuring the cisco 6509 to allow communication between 3550's and the router.
thanks
HI Pedro,
I don't have any switches with CatOS handy, but the configuration is very similar (with the set command):
C6500
vlan 100
vlan 200
interface FastEthernet3/1
description TO_3550_1
switchport trunk native vlan 100
interface FastEthernet3/2
description TO_3550_2
interface Vlan100
ip address 10.1.100.1 255.255.255.0
interface Vlan200
ip address 10.1.200.1 255.255.255.0
3550_1
interface FastEthernet0/1
description TO_C6500 3/1
interface range FastEthernet 0/2 - 24
interface Vlan100
description 3550_1 management
ip address 10.1.100.4 255.255.255.0
3550_2
description TO_C6500 3/2
switchport trunk native vlan 200
interface Vlan100
description 3550_2 management
ip address 10.1.200.4 255.255.255.0
HTH,
jerry
