07-08-2009 03:06 PM - edited 03-06-2019 06:39 AM
I have created three vlans
VLAN 100
VLAN 200
VLAN 300
The cisco 3550 are configure with each respective vlan 100, 200, and 300.
As soon as I plug the switch on the fiber module, I notices the switch been added to the proper VLAN. I have execute the command sh vlan 100, and it shows the switches configure for vlan 100. The same thing for vlan 200 and 300.
However, I notices some switches were added to the wrong vlans. Is there a command or configuration that I am doing that is causing this issue?
07-09-2009 12:02 PM
I think my configuration match to this configuration. We are able to have two switches working with the cisco 6509. Howeve, other switches on difeferent vlans 100 and 200 will not talk to the router.
The switches complaint the vlan mistmatch configuration. Therefore, on the router, the native vlan is set to 1 when it should be set to either 100 or 200 or even 300.
I'm not sure how the router can work fine with two swtiches but not the other switches. It is the same configuration on the rest of the switches.
My thinking is that there is something in the router that will not allow the other switches to work correctly.
Can you explain?
07-09-2009 12:06 PM
Hi Pedro,
You have to fix the native vlan mismatch first. This is can cause spanning tree loop which can lead to a network outage.
I saw your configuration has HSRP configured, do you have a 2nd pair of 6500? Also, Can your 3550's ping the default gateway? If not, make sure you have the following commands if the 3550's will be doing L2 only:
no ip routing
ip default-gateway x.x.x.1
HTH,
jerry
07-09-2009 04:15 PM
Hi Jerry,
no, the switches having issues can not ping their default gateway, or the router can't ping the switches ip address.
I started changing the switches using
vtp transparent
Can I use vtp server, too?
thanks
07-09-2009 04:40 PM
Jerry,
the ip default-gateway is this for the switch management ip address or the host ip address.
thanks
07-09-2009 05:15 PM
Hi Pedro,
The ip default-gateway command is for the switch management.
I don't suggest you to put the 3550's into server mode. You can leave them on client. If you've decided to changed the VTP mode to client from transparent, please make sure revision number is lower than the server.
jerry
07-09-2009 05:30 PM
Jerry,
thanks
07-09-2009 05:38 PM
Hi Pedro,
ip default-gateway is for the switch management. It has nothing to do with the host.
For example, when a host on VLAN100 is attached to the 3550, traffic will trunked to your 6500, if it wants to access anything outside VLAN100. It will use the ip address on the 6500's interface vlan 100 as its default router.
jerry
07-09-2009 05:48 PM
ok, let's start with my basic switch configuration. Can you critic or say if this is correct?
en
vlan database
vtp transparent
apply
exit
Config t
hostname LV-126B-AC-181-194
enable secret 5 $1$27ar$DnvrYBhnNW5eyTF2JgHIe.
enable password 7 0307585A5E5A744058
username admin password 7 1414115A54517F2732
!no aaa new-model
!ip subnet-zero
ip domain-name lv.psu.edu
ip ssh version 2
int range f0/1 - 24
description academic
switchport access vlan 100
switchport mode access
interface GigabitEthernet0/1
description Trunk to Cisco6509 router
switchport mode trunk
no shut
interface GigabitEthernet0/2
switchport mode dynamic desirable
interface Vlan1
no shut
interface Vlan100
description Academic
ip address 172.31.181.194 255.255.255.192
ip default-gateway 172.31.181.193
no shut
ip classless
ip http server
ip http secure-server
banner motd #
** WARNING: Unauthorized access to this system **
** is forbidden and will be prosecuted by law. **
** By accessing this system, you agree that your **
** actions may be monitored if unauthorized usage **
** is suspected. Only authorized Penn State **
** Lehigh Valley Campus **
line con 0
exec-timeout 0 0
line vty 0 4
password 7 1511085D5C7F7E283E
login local
transport input telnet ssh
line vty 5 15
password 7 094F4D584150421E1D
no login
end
wr
07-09-2009 05:51 PM
interface Vlan100
no shut
no ip routing
07-09-2009 05:58 PM
As far the cisco router, the OS version use set commands and not the latest cisco IOS. what do I need to eliminated or add to this configuration?
SRVRM-6509-MSFC1#sh run
Building configuration...
Current configuration : 3547 bytes
! Last configuration change at 08:52:47 EDT Thu Jul 9 2009
! NVRAM config last updated at 17:08:29 EDT Wed Jul 8 2009
version 12.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname SRVRM-6509-MSFC1
boot system bootflash:c6msfc2-psv-mz.121-13.E3.bin
boot bootldr bootflash:c6msfc2-boot-mz.121-13.E3.bin
no logging console
enable secret 5 $1$k3j8$vSFg2vXjmUMrtU/pxlCTX/
enable password 7 08121C430B0B0005424A
clock timezone EST -5
clock summer-time EDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
clock calendar-valid
ip subnet-zero
interface Loopback0
ip address 10.5.12.1 255.255.255.255
interface Vlan1
description Management VLAN
ip address 172.31.181.189 255.255.255.192
no ip redirects
standby 1 ip 172.31.181.129
standby 1 priority 120
standby 1 preempt
interface Vlan100
description Lab 214 VLAN
ip address 146.186.50.253 255.255.255.0
no ip redirects
standby 1 ip 146.186.50.1
standby 1 preempt
interface Vlan200
description LAB 200 VLAN
ip address 146.186.27.253 255.255.255.0
ip helper-address 146.186.27.3
no ip redirects
standby 1 ip 146.186.27.1
standby 1 preempt
interface Vlan300
description Wireless Lan
ip address 172.31.13.254 255.255.255.0
no ip redirects
standby 1 ip 172.31.13.1
standby 1 preempt
ip classless
ip route 146.186.27.0 255.255.255.0 172.31.181.129
ip route 146.186.50.0 255.255.255.0 172.31.181.193
ip route 172.31.13.0 255.255.255.0 172.31.13.1
no ip http server
access-list 101 permit ip 146.186.27.0 0.0.0.255 0.0.0.0 255.255.255.0
access-list 102 permit ip 146.186.27.0 0.0.0.255 0.0.0.0 255.255.255.0
access-list 103 permit ip 146.186.27.0 0.0.0.255 0.0.0.0 255.255.255.0
access-list 105 permit ip 146.186.27.0 0.0.0.255 host 172.31.181.131
access-list 106 permit ip 146.186.27.0 0.0.0.255 host 172.31.13.10
access-list 107 permit ip 146.186.27.0 0.0.0.255 0.0.0.0 255.255.255.192
access-list 121 permit ip 172.31.181.0 0.0.0.255 172.31.13.0 0.0.0.255
snmp-server community BR0WSE RO
snmp-server community b0wl1ng RW
snmp-server community private RW
snmp-server community BROWSE RO
snmp-server enable traps snmp authentication warmstart
snmp-server enable traps slb real virtual csrp
snmp-server enable traps flash insertion removal
snmp-server enable traps hsrp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps bgp
snmp-server enable traps rsvp
snmp-server enable traps frame-relay
snmp-server enable traps rtr
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps dlsw
snmp-server host 10.5.1.163 2
tacacs-server host 10.0.13.110
tacacs-server timeout 10
tacacs-server key 1cecacseng1key1
ntp clock-period 17179855
ntp source Loopback0
ntp master 2
ntp update-calendar
end
07-09-2009 06:09 PM
Hi Pedro,
I finally see what is the problem. On your 3550 LV-126B-AC-181-194, you cannot assign Vlan100 with the IP address of 172.31.181.194. The reason is this Vlan100 is the same Vlan100 on your 6500, they cannot be o different IP subnet. Also, which is your default gateway for management Vlan? Which router is 172.31.181.193? I can only see your default to be 172.31.181.129.
To get the 3550 to work, this is what you can do:
no interface vlan100
interface Vlan1
no shut
ip default-gateway 172.31.181.129
HTH,
jerry
07-09-2009 06:16 PM
Hi Jerry
I was assigned three subnets to manage the administrative switches, academic switches and the wireless switches.
Administrative switches 172.31.181.128/26
Academic Switches 172.31.181.128/26
Wireless Switches and APs 172.31.13.0/24
Do I use one address of the three subnets, or do I need to have a separate subnet for the router. And/or all network switches needs to be under one single subnet?
07-09-2009 06:28 PM
Hi Pedro,
Okay, let's talk about design. Since your Administrative switches and your Acadamic switches are in the same subnet, 172.31.181.128/26, they need to be on the same VLAN.
Since Wireless Switches and AP's are in 172.31.13.0/24, this need to be on a different VLAN.
I am assuming this is for management devices.
HTH,
jerry
07-09-2009 06:38 PM
ok,
If I understood correctly, the two subnets
172.31.181.128/26 and 172.31.181.192/26 needs to be let's say VLAN 200.
And, wireless network 172.31.13.0/24 on VLAN 300.
Now, before I carry away, I'm not sure if you notice the router has three vlans, 100, 200 and 300 with the gateway of each respective subnet.
thanks
07-09-2009 06:46 PM
Hi Pedro,
"172.31.181.128/26 and 172.31.181.192/26 needs to be let's say VLAN 200", these are two (2) different networks and they need to be on two (2) different VLAN, let's say 200 VLAN 201 and VLAN 202.
On your current 6500 configuration -
interface Vlan100
no ip redirects
standby 1 preempt
interface Vlan200
no ip redirects
standby 1 preempt
interface Vlan300
no ip redirects
standby 1 preempt
You are using VLAN100 for Lab 214 and VLAN 200 for Lab 200. You cannot reuse this VLAN ID for other address, this is the reason why the two (2) 3550's (VLAN100 and VLAN200) cannot take the the default gateway. VLAN300 is correct by comparing from the information you gave me.
HTH,
jerry
