cisco 6509(VSS) floating jitter jumps from 1 ms to 200 ms.
Colleagues welcome all.
Faced with the following problem
Ping from the laptop with IP 172.17.90.10/24 connected directly to the 6506 address of the gateway IP 172.17.90.1/24 on the Switch 6506 (VSS) on the same network 172.17.90.0/24.
Colleagues that may be a cause of this jitter (log quote below)? And jitter jumps from 1 ms to 200 ms.
IOS on switches next s2t54-ipbasek9_npe-mz.SPA.151-1.SY.bin.
Do I need to upgrade the IOS 15.1.2 on the switch to remove the floating jitter?
On both switches are two supervisor VS-SUP2T-10G 5 ports Supervisor Engine 2T 10GE w / CTS Rev. 1.5?
Processes on the switch following
c6506#show processes cpu sorted
CPU utilization for five seconds: 9%/0%; one minute: 15%; five minutes: 14%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
186 10755684 27432966 392 2.23% 3.96% 3.93% 0 slcp process
598 2540388 416980 6092 1.83% 0.97% 0.94% 0 Lif stats hw rea
597 1612192 180413 8936 1.03% 0.67% 0.64% 0 SEA write CF pro
139 2295172 35719071 64 0.79% 0.91% 0.83% 0 DiagCard2/-1
668 819640 2648836 309 0.63% 0.47% 0.36% 0 Spanning Tree
9 1008504 114066 8841 0.63% 0.43% 0.36% 0 Check heaps
55 2470580 33593623 73 0.55% 0.90% 0.88% 0 DiagCard1/-1
640 369632 769138 480 0.31% 0.18% 0.16% 0 QOS Stats Gather
615 181276 3554999 50 0.23% 0.05% 0.06% 0 DiagSatCtrl Proc
722 260612 202151 1289 0.23% 0.12% 0.12% 0 Hardware API bac
36 1159196 24866409 46 0.15% 0.44% 0.42% 0 IPC Seat Manager
699 81508 194571 418 0.07% 0.03% 0.00% 0 XDR receive
694 35284 5267431 6 0.07% 0.01% 0.00% 0 SCP async: LCP#1
365 8520 1740060 4 0.07% 0.00% 0.00% 0 Heartbeat
719 39232 636731 61 0.07% 0.01% 0.00% 0 CEF: IPv4 proces
15 0 2 0 0.00% 0.00% 0.00% 0 DDR Timers
16 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
18 0 11 0 0.00% 0.00% 0.00% 0 ifIndex Receive
17 1508 318 4742 0.00% 0.00% 0.00% 0 RF Slave Main Th
20 27316 282849 96 0.00% 0.00% 0.00% 0 EnvMon
19 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
22 184 26881 6 0.00% 0.00% 0.00% 0 Compute SRP rate
23 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API
21 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
25 1132 281887 4 0.00% 0.00% 0.00% 0 ARP Background
26 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
27 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
14 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest
29 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage
30 0 24 0 0.00% 0.00% 0.00% 0 IPC Apps Task
31 12 4482 2 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
C:\>ping 172.17.90.1 -l1300 -n1000 -t
Обмен пакетами с 172.17.90.1 по с 0 байтами данных:
Ответ от 172.17.90.1: число байт=0 время<1мс TTL=255
Ответ от 172.17.90.1: число байт=0 время=23мс TTL=255
Ответ от 172.17.90.1: число байт=0 время=25мс TTL=255
Ответ от 172.17.90.1: число байт=0 время=47мс TTL=255
Ответ от 172.17.90.1: число байт=0 время=13мс TTL=255
Ответ от 172.17.90.1: число байт=0 время=8мс TTL=255
Ответ от 172.17.90.1: число байт=0 время=200мс TTL=255
Ответ от 172.17.90.1: число байт=0 время=17мс TTL=255
Ответ от 172.17.90.1: число байт=0 время=4мс TTL=255
Статистика Ping для 172.17.90.1:
Пакетов: отправлено = 45, получено = 45, потеряно = 0
(0% потерь)
Приблизительное время приема-передачи в мс:
Минимальное = 0мсек, Максимальное = 200 мсек, Среднее = 2 мсек
1 ACCEPTED SOLUTION
VIP Super Bronze
Hi,It is probably a good idea
It is probably a good idea to upgrade, but before you do that contact TAC support and send them the output.
VIP Super Bronze
why give me here real advice
why give me here real advice why cisco 6506 have a floating jitter?
i cannot contract for TAC.
please colleagues help me here.
VIP Super Bronze
Why can't you contact TAC?As
As long as you have support contract you should be able to open a ticket.
And no, I don't work for TAC.
are you work in TAC?
73
