01-08-2012 08:33 PM - edited 03-07-2019 04:13 AM
hi Team,
Is it possible to convert 10 G ports to 1 G ports in WS-6708-10GE Module with any convertors.
pls help
Ajith
Solved! Go to Solution.
01-09-2012 04:35 AM
you can show this link to your customer
as you see only 10gb optics are supported and available
Riccardo
01-09-2012 03:05 AM
Hi Ajith,
no it is not possible as this module operates at 10Gb only.
Please rate and close the question if helpful.
regards,
Riccardo
01-09-2012 03:10 AM
Thanks Riccardo.Do you have Cisco link regarding this Since I need to submit to Customer.
Surely I will rate this.
Thanks & Regards,
Ajith
01-09-2012 04:35 AM
Riccardo
01-09-2012 08:34 PM
Hi Richardo,
Thanks for you answer. Is there any option to configure 1G uplink on this module. Since my WAN link is having 1 G uplink from another location.
Ajith
01-10-2012 01:48 AM
Hi Ajith,
no, the module can go to 10Gb only, there is no way to set the speed.
Riccardo
