Community Member
Cisco 7513 router power consumption
Dear
I need to check power comsumption on the cisco 7513 router that is running on our site now.
I googled the cisco web site but I could not find any information what I wanted
So does any one know the how to check the power consumption on the cisco 7500 router?
Community Member
Re: Cisco 7513 router power consumption
you can try this:
Router# show env all
Community Member
Thanks for your reply
I tried that
But it was not incloud that current consumption power on the router.
Does one any idea about that?
Community Member
strange...
is should show something like that:
PS1 +5V Current measured at 42.35 A (capacity 200 A)
PS1 +12V Current measured at 6.86 A (capacity 35 A)
PS1 -12V Current measured at 0.55 A (capacity 3 A)
PS1 output is 296 W
Community Member
Thanks for your quick reply!
I already see this output But it was not something that I want result.
Forexample,Catlayst6500 series have command to see the power comsumption that is "show power status all".
I need to see the current power comsumption
that like catalyst 6500 series.
Is there no way to check the power comsumption on the cisco 7513 router?
Thanks!
Community Member
Not sure... maybe cisco TAC can help you, have you tried that?
804
