Cisco 7600: How to extract inner vlans from q-in-q vlan?
Hello.
I've got a 10GE trunk interface from our partner. One vlan (id 1149) that comes on this port is a q-in-q vlan carring four inner vlans. How can I extract them?
Current interface configuration:
interface TenGigabitEthernet3/4
description XXXXXXX
switchport
switchport trunk allowed vlan 1140-1150
switchport mode trunk
Re: Cisco 7600: How to extract inner vlans from q-in-q vlan?
I am not sure I understand exactly.
But if you are receiving double tag traffic with 1149 as outer dot1q and let's say vlan x,y and z as inner vlan.
You need to select one output port to which you will send the traffic.
If this port is on a regular lan line card (any Ws-X67xx) for example you can configure that port as Dot1q tunnel port :
interface gig 1/1
description XXXXXXX
switchport
switchport mode dot1q-tunnel
switchport mode access vlan 1049
--> with that config we will remove vlan 1049 from each packet incoming on the ten gig int with vlan 1049 and sends only the inner vlan out on gig 1/1 for example.
config guide for dot1q tunneling is at : http://www.cisco.com/en/US/partner/docs/routers/7600/ios/12.2SR/configuration/guide/dot1qtnl.html
If your egress line card would be an Es-20, Es+ or sip-400, you may do the same with EVC config using service instances. Some info on service instance can be found in :
http://www.cisco.com/en/US/partner/docs/routers/7600/install_config/ES40_config_guide/es40_chap4.html
Roland
Hi Roland,
Yes vlan 1149 used as outer dot1q and vlan 143,156,841 as inner vlan.
In my setup there's no ES20 card, so I have to follow your sugesstion with the output port. Thanks for configuration example!
Is there any possiblity to remove the outer dot1q vlan on 7600's SVI?
hi,
No on SVI on 7600 you cannot do that.
Actually you cannot even route a double tagged packet on an SVI.
if you only have LAN line card I fear you are limited to the dot1q tunnel access port.
Roladn
448
