Cisco 7600 problem ""bandwidth command is not supported in output direction for this interface""
Dr.X
Level 2
Level 2
i cant apply qos on cisco 7604 platform ,
i just want to gurantee cir for a specific subnet of ips .
i have a problem , when i apply the qos on an interface , i have the errro below :
<<bandwidth command is not supported in output direction for this interface >>
Gateway7600#sh version
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(4)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 20-Jul-12 18:18 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(4)S, RELEASE SOFTWARE (fc1)
Gateway7600 uptime is 33 weeks, 3 days, 8 hours, 53 minutes
Uptime for this control processor is 12 weeks, 3 days, 8 hours, 57 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 06:26:11 UTC Sat Apr 20 2013
System image file is "sup-bootdisk:c7600s3223-adventerprisek9-mz.152-4.S.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7604 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID FOX1509G2DK
R7000 CPU at 300MHz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
1 Virtual Ethernet interface
9 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
here is an example :
Gateway7600(config)#interface gigabitEthernet 1/8
Gateway7600(config-if)#service-policy output test
Configuration failed on GigabitEthernet1/8
Gateway7600(config-if)#interface gigabitEthernet 1/8
Jul 16 15:24:49.697: %QOS-6-POLICY_INST_FAILED:
Service policy installation failed
Gateway7600(config-if)#service-policy input
Gateway7600(config-if)#service-policy input test
bandwidth command is not supported in input direction for this interface
0 Replies 0
