Webcast-Catalyst9k
Cisco 7606 sup720 with MSCF: upgrade to 122-33.SRE6 fail
I faced with problem while i was attemping to upgrade CISCO7606 (R7000) from 12.2(33)SRE1 to 12.2(33)SRE6.
rommon 2 > boot c7600s72033-advipservices-mz.122-33.SRE6.bin
Loading image, please wait ...
Invalid device specified
Booting from default device
Initializing ATA monitor library...
string is bootdisk:c7600s72033-advipservices-mz.122-33.SRE1.bin
monitor: command "boot" aborted due to user interrupt
rommon 3 >  [A [B
monitor: command " [A [B" not found
rommon 4 > boot bootdisk                        flash:c7600s72033-advipservices-mz.122-33.SRE6.bin
device does not contain a valid magic number
boot: cannot open "bootdisk:"
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
loadprog: error - on file open
boot: cannot load "flash:c7600s72033-advipservices-mz.122-33.SRE6.bin"
Another commands:
cmx## show bootvar
cmx## show bootvar               show bootvar
BOOT variable = boot,1;
CONFIG_FILE variable =
BOOTLDR variable =
Standby not ready to show bootvar
cmx-beeline-2#show version | in image
System image file is "bootdisk:c7600s72033-advipservices-mz.122-33.SRE1.bin"
------------------ show sup-bootdisk: all ------------------
-#- --length-- -----date/time------ path
2 33554432 Nov 30 2010 08:58:08 +03:00 sea_log.dat
3 152889292 Nov 29 2010 17:41:54 +03:00 c7600s72033-advipservices-mz.122-33.SRE1.bin
4 154163148 Mar 26 2012 01:28:36 +03:00 c7600s72033-advipservices-mz.122-33.SRE6.bin
What could be reason of the issue?
Thanks.
1 ACCEPTED SOLUTION
Purple
Re: Cisco 7606 sup720 with MSCF: upgrade to 122-33.SRE6 fail
      You have no specific boot statement so it will load the first file it finds in flash. Boot statement should read "boot system flash sup-bootdisk:c7600s72033-advipservices-mz.122-33.SRE6.bin   .  then write mem .
Purple
Perhaps you are right. I'try and let you know.
Before that I typed only: boot system sup-bootdisk:c7600s72033-advipservices-mz.122-33.SRE6.bin . then write mem .
Thanks.
Thank you. We've upgraded cisco now.
730
