Community Member
Cisco 826 Flash upgrade
I have purchased a 8MB Mini-Flash card for a C826 but it does not seem to be recognized by the router.
Is there any special config to do (like setting a flag or formatting) before the extra flash is available?
1 REPLY
Re: Cisco 826 Flash upgrade
Whats the part number of the new flash card being used ?
Did you check out for the part code compatible with the router model before buying it ?
As per the data sheet you can go upto 16MB flash on your router..
http://cisco.com/en/US/products/hw/routers/ps380/products_data_sheet09186a0080088736.html
regds
109
