Cisco 876 flash file
I would like to tell me which is the file of cisco ios 12.4 T
In other words, it should be like the below file:
c870-advsecurityk9-mz.124-4.T4.bin
and should be the appropriate file for the 876 router.
1 ACCEPTED SOLUTION
Re: Cisco 876 flash file
Hi Elias,
The latest in 12.4T train is "c870-advsecurityk9-mz.124-15.T1.bin" but the latest in 12.4 main train is "c870-advsecurityk9-mz.124-11.XW2.bin"
You can also use Feature Navigator tool and then click on the option for "serach by platform" and select 876 from dropdown and then select major release and then feature set which you are looking for.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Ankur
*Pls rate all helpfull post
1 REPLY
Hi Elias,
Ankur
160
