Cisco 877 and 2960 to share ADSL - config problem.
Hi All,
I've got a new 877 and 2960 switch that I'm trying to setup so each port can only see the router via the trunk port and not each other.
I've configured and confirmed 802.1q trunking between fa0/1 and fa0 and can ping between a workstation attached to the switch and the router.
As soon as I create the vlan and assign the workstation port to the vlan I can no longer communicate with the router.
The vlan is in the allowed range - what am I missing?
Thanks is advance.
W
Re: Cisco 877 and 2960 to share ADSL - config problem.
Hi Warren
can you post out the config of both your router and the switch ?
regds
Configs as requested... Don't worry too much about the names and time settings etc, once the setup is working correctly I'll correct the simple stuff.
Thanks again!
switch#show vlan
VLAN Name Status Ports
1 default active Fa0/2, Fa0/3, Fa0/4, Fa0/5
Fa0/6, Fa0/7, Fa0/8, Fa0/9
Fa0/10, Fa0/11, Fa0/12, Fa0/13
Fa0/14, Fa0/15, Fa0/16, Fa0/17
Fa0/18, Fa0/19, Fa0/20, Fa0/21
Fa0/23, Gi0/1, Gi0/2
22 laptop active Fa0/22
24 desktop active Fa0/24
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
22 enet 100022 1500 - - - - - 0 0
24 enet 100024 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
switch#show run
Building configuration...
Current configuration : 1460 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname switch
enable secret 5 $1$hNTN$eWkptt9QSN1k7Gx/FsvcB/
enable password cisco1
no aaa new-model
ip subnet-zero
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
switchport access vlan 22
interface FastEthernet0/23
interface FastEthernet0/24
switchport access vlan 24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 10.10.10.2 255.255.255.0
no ip route-cache
ip default-gateway 10.10.10.1
ip http server
control-plane
line con 0
line vty 0 4
password cisco1
no login
line vty 5 15
password cisco1
no login
end
switch#
And router :
Router :
yourname#show run
Current configuration : 6143 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname yourname
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret xxx
no aaa new-model
resource policy
clock timezone PCTime 10
clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 2:00
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
ip ssh time-out 60
ip ssh authentication-retries 2
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
crypto pki trustpoint TP-self-signed-786425023
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-786425023
revocation-check none
rsakeypair TP-self-signed-786425023
crypto pki certificate chain TP-self-signed-786425023
username cisco1 privilege 15 secret 5xxx
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
no snmp trap link-status
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1412
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
ip inspect DEFAULT100 out
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username aaaa password xxx
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 100 remark auto generated by Cisco SDM Express firewall configuratio
n
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by Cisco SDM Express firewall configuratio
n
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 10.10.10.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Okay, figured it out. Was trying way too hard... Thought I'd post this in case someone else has the same query.
The 2960 switch has a 'protected' mode function on a per-port basis. Use the command 'switchport mode protected' and this will force the switch to send all traffic to a l3 device - the dsl router.
No vlans, no trunking, simple.
375
