Cisco 877 / QoS
Hi Folks,
I have a question about my Cisco 877, I am running "c870-advsecurityk9-mz.124-20.T1" but when I try to set-up QoS under SDM it says I am running the wrong IOS. Also under Firewall and ACL I am not able to set-up any P2P protection (again it says I am running the wrong IOS).
Question is, which IOS supports these features?
Cheers.
M
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Cisco 877 / QoS
M
For QOS support you need either Advanced IP Services or Advanced Enterprise - see attached Q&A table, about 1/4 of the way down under "General Software Features"
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/prod_qas0900aecd8028a982.html
Not too sure about the P2P protection - do you mean DMVPN or GETVPN ?
Jon
Re: Cisco 877 / QoS
M
Jon
Re: Cisco 877 / QoS
Hi Jon,
Thanks mate, that table was exactly the type of thing I was looking for (never easy finding anything on the Cisco site).
For P2P protection, I will see if it's included in this image and let you know.
Thanks for the speedy reply.
M
Re: Cisco 877 / QoS
Jon,
That image worked fine foe P2P protection. I can now block bittorrent etc.
Have a good day mate.
M
389
