Webcast-Catalyst9k
Cisco 881 SDSL with ADSL bkup Configuration.
Hello community.
i'm looking for a cisco 881 configuration with SDSL line as nominal and ADSL as backup.
could someone of you help.
Best Regards
Hi there,
IP SLA will work when both circuits are connected to same router, as you can see, there are two default-route but one has higher cost (i.e. route cost not the $ )
Here is the config below.
Try this out...
track 10 ip sla 1 reachability
delay down 10 up 10
ip route 0.0.0.0 0.0.0.0 172.16.2.2 name DEFAULT-ROUTE track 10
ip route 0.0.0.0 0.0.0.0 2.2.2.1 20 name BACKUP-DEFAULT-ROUTE
ip route 4.2.2.2 255.255.255.255 172.16.2.2 permanent
ip sla 1
icmp-echo 4.2.2.2 source-ip 172.16.2.1
timeout 20000
frequency 10
ip sla schedule 1 life forever start-time now
ip sla enable reaction-alerts
Hope that helps.
Rizwan Rafeek.
Hi Rizwan
thank you for the response that will serve me later ..
I'm destabilized by vlans in cisco 881 since I can not assign IP addresses to physical inrfaces ... as well as by the absence of the ATM interface. since my router does not XDSL.Pour card information, I have only RJ45 interfaces ..
I feel that it'll be a little hard before I can walk to everything.
if you had that case how will you configure the interfaces?
B regads
I understand, there is a hardware limitation on your router but you still have one routable FastEthernet4 interface, which can be assign for PPPoE authentication for one ISP connection.
For the second ISP connection, I am not sure.
Sorry, I couldn't help you with hardware limitation.
Pls rate any help tips.
thank you Rizwan.
here is the begin of configuration i m starting
interface FastEthernet0
description -- To the LAN 1 --
switchport access vlan 2
no ip address
duplex full
speed 100
interface FastEthernet1
description -- To the LAN 2 --
switchport access vlan 3
no ip address
duplex full
speed 100
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
description -- To the ADSL Backup Line --
no ip address
shutdown
interface FastEthernet4
description --TO the SDSL Maine Line--
no ip address
no ip route-cache
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
ip address 10.69.1.254 255.255.255.0
interface Vlan3
ip address 10.69.2.254 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
Can you enable on "interface FastEthenet3" pppoe enable, doubt it? If you cannot then cannot host two circuit on this router.
Hi Rizwan.
Here are the configuration to which I arrived. Once I have the definitve WAN IP address, I will put the IP SLA that you gave me.
but if you can look and tell me if there are errors.
I remind you that I will connect the router to two Box that will be responsible for authentication etc. ..
Thank you for advance.
no ip address
duplex full
speed 100
no ip address
duplex full
speed 100
no ip address
shutdown
no ip address
pppoe enable
pppoe-client dial-pool-number 2
no ip address
no ip route-cache
duplex auto
speed auto
pppoe enable
interface Vlan1
ip helper-address 10.65.50.1
ip helper-address 10.65.50.88
no ip route-cache
interface Vlan2
interface Vlan3
no ip address
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap
crypto map vpn
interface Dialer2
mtu 1492
encapsulation ppp
dialer pool 2
dialer-group 2
crypto map vpn
no ip http server
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2 250
ip route 10.65.0.0 255.255.0.0 Dialer1
ip route 10.65.0.0 255.255.0.0 Dialer2 250
ip route 10.254.0.0 255.255.0.0 Dialer1
ip route 10.254.0.0 255.255.0.0 Dialer2 250
Hi there,
FYI...
These two routes above highlighted includes everything, I mean everything and four below routes really not needed.
Were you able to test individually each DSL connection to make sure their PPPoE working fine?
thanks
youre right. 0.0.0.0 0.0.0.0 is enough. i just added it
i have not yet tested individually DSL..I ll telle you when did.
but what do you think about the rest of the configuration  ..specially the interfaces ??
They look fines to me.
869
