12-02-2013 04:46 PM - edited 03-07-2019 04:53 PM
I am trying to configure the 881w router and I have never used the Cisco cp express before. I am wanting to configure the 881w to replace our SA520w. What is the best way to go about it?
Tabaitha
12-02-2013 10:42 PM
HI ,
Please check out this:
or
http://www.cisco.com/en/US/docs/routers/access/cvo/880-870-cvo.html
Dont forget to rate helpful posts.
01-02-2014 09:40 AM
I have already whent o that site and it does not help. If i change the IP address for my router i get locked out and have to set back to factory. I am wondering is there an easy way to configure it.
Tabaitha
01-02-2014 09:47 AM
"If i change the IP address for my router i get locked out and have to set back to factory."
After you change the address to something else, change your workstation to be on the same network as the new address that you've put on the router. You can then finish the configuration.
So, if you're changing the address on the router to "192.168.1.1", you can change your address on your workstation to something like "192.168.1.50" or something in the same network.
HTH,
John
*** Please rate all useful posts ***
01-02-2014 09:58 AM
Hi John,
Thank you for the advice but this i knew. I am trying to configure the cisco 881w with the same configuration as our current one SA520 router.
Tabaitha
01-02-2014 10:03 AM
Tabaitha
Once you change the IP you will be locked out unless -
a) you are on the same subnet as John says
or
b) the router has a route back to the subnet where your PC is.
We can't really help you if you don't provide enough information ie. you want the same configuration as your SA520 but we have no idea of how that is setup, whether you have multiple vlans/subnets in your network, what IP you are trying to give your router and what IP your PC is using etc..
Jon
01-02-2014 11:05 AM
Hi Jon,
A) Yes i am on the same subnet.
B) I am Trying to set it up with the following:
IP Address : 207.231.79.188
Subnet Mask: 255.255.255.248
Gateway: 207.231.79.185
C) The PC is using on the 520w router public 207.231.79.186
Priviate IP is 192.168.2.249
Tabaitha
01-02-2014 10:04 AM
I'm not quite clear on what your question is then. What are you trying to accomplish? I can't help with the web interface on configuring, but if you're aware that you need to reconnect after changing the address, what problems are you having?
HTH,
John
01-02-2014 09:49 AM
Agree with John
Here are more docs:
http://tekyhost.com/how-to-configure-cisco-881-series-router-with-cable-modem-and-static-ip/
01-02-2014 11:07 AM
Do you know how to get the configuration file from the SA520w router as a .txt file and not the .cfg? If i can get it as a .txt. i can upload it to the other router to get the same configurations.
Tabaitha
01-02-2014 11:11 AM
Tabaitha,
I'm not sure about that model, but I'd be surprised if the configuration carried over without a lot of modification. It would be best if you reconfigured the new router to be like the old, but not expect the old configuration to blindly carry over to the new appliance. I could be wrong, and maybe either Jon or Sandeep has more information.
John
01-02-2014 11:14 AM
John,
I know someone that works within cisco but is not on the technical side and said if i can get the SA520w configuration file as a .txt then i will be able to get what i need for the other router.
Tabaitha
01-02-2014 11:18 AM
Tabitha
Like John i would be surprised if that would work. However you should be able to open a .cfg file with notepad or wordpad and save as a .txt file or just rename the .cfg to a .txt file.
From one of your responses you say you are trying to add a public IP and your PC is on a private IP. Unless the interface you are changing is the one you are connecting to via your PC then you shouldn't get cut off.
Apologies for not being able to give specific answers, it's just that most of us use the CLI for this sort of thing so it's difficult to say exactly what is goign wrong.
Jon
