Cisco 881W switch connection issue
bryanlooi
I have a cisco 881W which seems to have an issue connecting to s 3COM Smart switch. Systems connected to the 3COM would not register an ip address. HOwever if i switch the 3COM to a unmanaged switch, the problems dissapears. I was wondering if there is a configuration that is needed to ensure than the cisco 881W can communicate with a smart switch. The WAM connection is coming from a modem with ADSL
This is my current configuration.
Any help would be gratefull.
version 15.2
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip dhcp excluded-address 10.10.10.51 10.10.10.254
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 202.188.0.133 8.8.8.8
lease infinite
ip domain name yourdomain.com
ip name-server 202.188.0.133
ip name-server 8.8.8.8
ip cef
no ipv6 cef
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport mode trunk
no ip address
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip directed-broadcast
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 199 interface FastEthernet4 overload
access-list 199 permit ip any any
no cdp run
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
18 Replies 18
Hey Julio
Do i do these commands with the switch connected or not, Because if I do it with the switch, I cannot get an IP and thus cannot get these commands and connect to the router. The current set up is cable modem > Switch > Router. The 3Com cannot get an IP from the router. So now ive removed the switch and is connected directly to the router.
Hey bud you are making things to complicated
So network setup is
Comcast router---3com L2 switch---Router
When you connect the 3com the router does not get an Ip on it's Fa 0/4 interface??
but when you do not have the switch it does??
Is that right???????
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Sorry for making it complicated. But you are absolutely correct. That is the setup.
That is correct. Absoulutely correct. If connected to the Switch i will not get an IP, but if i connect straight to the router, I will get an IP
Any ideas?
Bryan Looi
Julio Carvajal
Then you are looking on the wrong place.
The issue is within the 3com switch.
Make sure the connection to the modem is up.
Check that both ports on the 3 com are access ports and connect to the same vlan.
That's all bud.
Do remember to rate all of our answers.
Julio Carvajal
