Cisco 887 VDSL2 over POTS Router
Chris Ingram
Has anyone configured one of these?  I can't find any information about how to configure the VDSL controller, anywhere.
I have one, hooked up to a VDSL line, ready to configure.  Now I can't find any information on Cisco's website about configuring this router.
Chris Ingram
I've found out some information (just in case someone out there is interested).  There is a Bug ID associated with the router due to the fact that the ATM interface is not supported in the IOS.  I had noticed it wasn't showing up and therefore was confused.  Otherwise, the configuration is very similar to a regular DSL 887 router.
Qoute from TAC:
"ATM functionality is not yet supported for VDSL controller and that's why we can only have an Ethernet interface for the corresponding VDSL interface
An improvement bug, CSCsr27209, has already been filed."
I tried to look this bug ID up.........
Dear valued Cisco Bug Toolkit customer, the bug ID CSCsr27209 you searched contains proprietary information that cannot be disclosed at this time; therefore, we are unable to display the bug details. Please note it is our policy to make all externally-facing bugs available in Bug Toolkit to best assist our customers. As a result, the system administrators have been automatically alerted to the problem.
While we are working to resolve this issue, we invite you to reach out to the experts on the
Bug Toolkit Support Community. You may find answers there to your Bug Toolkit questions, or post your feedback on our forum as well. Thank you.
If anyone knows, or has links to, anymore information about this.  I'd be very interested in it.
Chris
Did you ever get u're 887 Working, i am having issues with it just synch up for some reason and was woundering if u were able to get it working..
can u please post u're config ig u have?
did any one get to configure this?
i have a 887W, I have managed to configure my VDSL side and have an ip address from the ISP , DNS is working from the router and i can ping both sides
My inetrenal side is also working with DHCP and VLANS fine
My problem i I cant get it to NAT between the VLAN and ethernet 0 interface which my VDSL Line is on
version 15.1
no service pad
hostname router1
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 10
service-module wlan-ap 0 bootimage autonomous
ip source-route
ip dhcp pool Internal
   import all
   network 10.10.48.0 255.255.255.0
   default-router 10.10.48.1
   dns-server 198.161.156.1
ip cef
ip domain name networksolutions.ca
ip name-server 220.180.25.254
ip name-server 221.177.15.1
no ipv6 cef
license udi pid CISCO887VW-GNA-K9 sn FGL152523H1
vtp interface Vlan10
controller VDSL 0
interface Ethernet0
ip address dhcp
ip nat outside
ip nat enable
no ip virtual-reassembly in
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
switchport access vlan 148
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
no ip address
interface Vlan10
ip address 10.10.10.10 255.255.255.0
interface Vlan148
ip address 10.10.48.1 255.255.255.0
ip nat inside
ip nat enable
router eigrp 10
network 10.10.0.0 0.0.255.255
router rip
version 2
network 10.0.0.0
network 50.0.0.0
ip default-gateway 90.150.42.158
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool pool1 10.10.48.0 10.10.48.255 netmask 255.255.255.0
ip nat pool matty 10.10.48.1 10.10.48.100 prefix-length 24
ip nat inside source list 7 pool matty
ip nat inside source list acl1 pool pool1
ip route 0.0.0.0 255.255.255.0 Ethernet0
logging esm config
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 7 permit 10.10.48.0 0.0.0.31
control-plane
