Cisco 888 acts as default router
My company use Cisco 888 modems to bridge vlans to users at remote locations. Bridging works fine. But for some reason Cisco 888 modems announces that they know about subnet they are in, and result is a loop (time to live exceeded). This is what I get then I traceroute Cisco 2950 from workstation:
root@:~# traceroute 172.31.250.6
traceroute to 172.31.250.6 (172.31.250.6), 30 hops max, 60 byte packets
1  10.6.7.253 (10.6.7.253)  1.416 ms  1.738 ms  2.001 ms
2  172.31.254.42 (172.31.254.42)  0.542 ms  0.923 ms  1.126 ms
3  172.31.245.16 (172.31.245.16)  1.123 ms  1.117 ms  1.110 ms
4  192.168.208.25 (192.168.208.25)  1.113 ms  1.105 ms  1.098 ms
5  192.168.209.18 (192.168.209.18)  2.428 ms  2.806 ms  3.174 ms
6  192.168.208.38 (192.168.208.38)  2.778 ms  5.825 ms *
7  172.31.250.30 (172.31.250.30)  2.352 ms  2.526 ms  2.688 ms
8  172.31.250.30 (172.31.250.30)  2.859 ms  3.037 ms  3.221 ms
9  172.31.250.30 (172.31.250.30)  3.403 ms  2.258 ms  2.241 ms
10  172.31.250.30 (172.31.250.30)  2.399 ms 172.31.250.31 (172.31.250.31)  3.355 ms 172.31.250.30 (172.31.250.30)  3.095 ms
11  172.31.250.31 (172.31.250.31)  3.343 ms 172.31.250.30 (172.31.250.30)  3.842 ms  4.087 ms
12  172.31.250.30 (172.31.250.30)  4.268 ms  4.492 ms  4.752 ms
13  172.31.250.30 (172.31.250.30)  5.124 ms 172.31.250.31 (172.31.250.31)  5.569 ms  6.132 ms
14  172.31.250.31 (172.31.250.31)  6.744 ms 172.31.250.30 (172.31.250.30)  6.466 ms 172.31.250.31 (172.31.250.31)  6.158 ms
15  172.31.250.31 (172.31.250.31)  6.369 ms 172.31.250.30 (172.31.250.30)  5.724 ms  5.785 ms
16  172.31.250.30 (172.31.250.30)  5.857 ms  5.737 ms  5.773 ms
17  172.31.250.30 (172.31.250.30)  6.123 ms  6.380 ms  6.557 ms
18  172.31.250.30 (172.31.250.30)  6.812 ms  6.948 ms  6.727 ms
19  172.31.250.31 (172.31.250.31)  6.559 ms 172.31.250.30 (172.31.250.30)  6.435 ms  6.492 ms
20  172.31.250.31 (172.31.250.31)  6.555 ms  6.612 ms 172.31.250.30 (172.31.250.30)  6.806 ms
21  172.31.250.30 (172.31.250.30)  6.981 ms  7.121 ms  7.329 ms
22  172.31.250.30 (172.31.250.30)  7.220 ms  7.267 ms  7.288 ms
23  172.31.250.30 (172.31.250.30)  7.134 ms  7.047 ms  7.196 ms
24  172.31.250.30 (172.31.250.30)  7.254 ms  7.118 ms  7.194 ms
25  172.31.250.30 (172.31.250.30)  7.400 ms  7.319 ms  7.309 ms
26  172.31.250.30 (172.31.250.30)  7.328 ms  7.431 ms  7.459 ms
27  172.31.250.30 (172.31.250.30)  7.557 ms  7.448 ms  7.433 ms
28  172.31.250.30 (172.31.250.30)  7.143 ms  6.821 ms  6.499 ms
29  172.31.250.30 (172.31.250.30)  6.180 ms  6.053 ms  5.782 ms
30  172.31.250.30 (172.31.250.30)  5.324 ms  5.223 ms  4.772 ms
If I shut both Cisco 888 modems problem disappears. I already tried on Cisco 888 Vlan208 no ip redirects and no ip proxy-arp.  I attached network scheme with configs. Maybe someone could share explanation or had same problem and has a solution. Putting modems into another subnet is not an option.
Thanks.
212
