05-21-2010 01:58 PM - edited 03-06-2019 11:12 AM
I am having problem with a simple NAT configuration, and not able to figure out. I can not connect to the Internet. I am not able to find enough information about NAT-NVI: translation failed (A) error.
thanks
here is the config
interface FastEthernet8
ip address 11.27.19.25 255.255.254.0
ip nat outside
ip nat enable
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0
ip nat inside
ip nat enable
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 11.27.19.24
ip route 192.168.1.0 255.255.255.0 GigabitEthernet0
ip nat inside source route-map NAT interface FastEthernet8 overload
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
route-map NAT permit 10
match ip address 100
and here is the debug:
May 21 20:54:05.578: NAT-NVI: translation failed (A), dropping packet s=11.27.19.25 d=11.27.100.1
*May 21 20:54:05.578: NAT: s=192.168.1.1->11.27.100.1, d=11.27.19.25 [50914]
*May 21 20:54:06.590: NAT: s=192.168.1.2->11.27.19.25, d=11.27.100.1 [629]
*May 21 20:54:06.594: NAT: UDP s=54054->1056, d=53
*May 21 20:54:06.594: NAT: UDP s=53, d=1056->54054
*May 21 20:54:07.606: NAT: s=192.168.1.2->11.27.19.25, d=11.27.100.1 [630]
*May 21 20:54:07.606: NAT: UDP s=54054->1056, d=53
*May 21 20:54:07.610: NAT: UDP s=53, d=1056->54054
*May 21 20:54:09.618: NAT: s=192.168.1.2->11.27.19.25, d=11.27.100.1 [631]
*May 21 20:54:09.618: NAT: UDP s=54054->1056, d=53
*May 21 20:54:09.622: NAT: UDP s=53, d=1056->54054
*May 21 20:54:13.626: NAT: s=192.168.1.2->11.27.19.25, d=11.27.100.1 [632]
*May 21 20:54:13.626: NAT: UDP s=54054->1056, d=53
*May 21 20:54:13.630: NAT: UDP s=53, d=1056->54054
*May 21 20:54:21.206: NAT: expiring 11.27.19.25 (11.27.19.25) udp 1044 (59513)
*May 21 20:54:22.230: NAT: expiring 11.27.19.25 (11.27.19.25) udp 1045 (63372)
*May 21 20:54:27.350: NAT: expiring 11.27.19.25 (11.27.19.25) udp 1046 (63623)
*May 21 20:54:30.422: NAT: expiring 11.27.19.25 (192.168.1.2) udp 58745 (58745)
*May 21 20:54:43.734: NAT: expiring 11.27.19.25 (11.27.19.25) udp 1047 (54640)
*May 21 20:54:45.270: NAT: expiring 11.27.19.25 (11.27.19.25) udp 1048 (52768)
*May 21 20:55:00.926: NAT: s=192.168.1.2->11.27.19.25, d=11.27.100.1 [633]
*May 21 20:55:00.930: NAT: UDP s=52856->1057, d=53
*May 21 20:55:00.930: NAT-NVI: translation failed (A), dropping packet s=11.27.19.25 d=11.27.100.1
*May 21 20:55:00.930: NAT: s=192.168.1.1->11.27.100.1, d=11.27.19.25 [50919]
*May 21 20:55:01.654: NAT: expiring 11.27.19.25 (192.168.1.2) udp 63972 (63972)
*May 21 20:55:01.938: NAT: s=192.168.1.2->11.27.19.25, d=11.27.100.1 [634]
*May 21 20:55:01.942: NAT: UDP s=52856->1057, d=53
*May 21 20:55:01.942: NAT: UDP s=53, d=1057->52856
*May 21 20:55:02.954: NAT: s=192.168.1.2->11.27.19.25, d=11.27.100.1 [635]
*May 21 20:55:02.954: NAT: UDP s=52856->1057, d=53
*May 21 20:55:02.958: NAT: UDP s=53, d=1057->52856
*May 21 20:55:04.966: NAT: s=192.168.1.2->11.27.19.25, d=11.27.100.1 [636]
*May 21 20:55:04.966: NAT: UDP s=52856->1057, d=53
*May 21 20:55:04.970: NAT: UDP s=53, d=1057->52856
*May 21 20:55:08.974: NAT: s=192.168.1.2->11.27.19.25, d=11.27.100.1 [637]
*May 21 20:55:08.974: NAT: UDP s=52856->1057, d=53
*May 21 20:55:08.978: NAT: UDP s=53, d=1057->52856
*May 21 20:55:13.942: NAT: expiring 11.27.19.25 (192.168.1.2) udp 54054 (54054)
Solved! Go to Solution.
05-21-2010 02:14 PM
Hi Ercan,
Why do you have a static route to the connected interface?
Also can you change your current NAT statement to this and try testing again?
ip nat inside source list 100 interface FastEthernet8 overload
Reza
05-22-2010 12:20 AM
thanks
here is the config
ip nat outside
ip nat enable
duplex auto
speed auto
ip nat inside
ip nat enable
duplex auto
speed auto
As Reza Pointed what is the need for 192.168.1.0 route towards the interface and as you have created a route map apply the route map on the interface Gigethernet 0 as per the below example.
Router(config)# interface Fast Ethernet 3/0
Router(config-if)#ip policy route-map reroute10traffic
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
05-21-2010 02:14 PM
Hi Ercan,
Reza
05-24-2010 05:56 AM
Hi Reza,
having a static route to that network was not problem, it was the route-map settings in the config. it works fine now. NAT also works with ACL you put in your reply.
Ercan
05-22-2010 12:20 AM
thanks
here is the config
ip nat outside
ip nat enable
duplex auto
speed auto
ip nat inside
ip nat enable
duplex auto
speed auto
Hope to Help !!
Ganesh.H
05-24-2010 05:57 AM
"Router(config-if)#ip policy route-map..." was the missing part...
thanks
05-24-2010 06:02 AM
That's Great !! Your problem has been solved
Ganesh.H
Ganesh Hariharan Iyer
Tata Consultancy Services
Mailto: ganeshh.iyer@tcs.com
Website: http://www.tcs.com
