Community Member
Cisco adsl 877
I have the below configuration and would like to find out why I cannot pass web traffic from the ADSL conncection. Do I miss anything on the conf below?
Thank you in advance.
Building configuration...
Current configuration : 4815 bytes
version 12.4
no service pad
service password-encryption
hostname router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
dot11 ssid wifi
vlan 1
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 7 0707244543084850444659
no ip source-route
ip dhcp excluded-address 192.168.1.254
ip dhcp pool wifipool
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server x.x.x.x y.y.y.y
update arp
ip cef
no ip bootp server
no ip domain lookup
ip domain name local
ip name-server 192.168.1.254
no ipv6 cef
username ….
archive
log config
hidekeys
path flash:config
write-memory
ip tcp selective-ack
ip tcp timestamp
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers aes-ccm
broadcast-key vlan 1 change 30
ssid wifi
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Dialer0
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username xxxxxxxxxxxx password 7 xxxxxxxxxxx
ppp ipcp dns request
ppp ipcp route default
interface BVI1
ip address 192.168.1.254 255.255.255.0
ip access-group 102 in
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark The local LAN.
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 remark Where management can be done from.
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 101 remark Traffic allowed to enter the router from the Internet
access-list 101 deny ip 0.0.0.0 0.255.255.255 any
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip 169.254.0.0 0.0.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.0.2.0 0.0.0.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 224.0.0.0 0.15.255.255 any
access-list 101 deny ip any host 255.255.255.255
access-list 101 permit tcp any any eq 1723
access-list 101 permit gre any any
access-list 101 permit tcp any any eq 22
access-list 101 permit tcp any any eq telnet
access-list 101 permit tcp any any eq domain
access-list 101 permit udp any any eq domain
access-list 101 deny icmp any any echo
access-list 101 deny ip any any log
access-list 102 remark Traffic allowed to enter the router from the Ethernet
access-list 102 permit ip any host 192.168.1.254
access-list 102 deny ip any host 192.168.1.255
access-list 102 deny udp any any eq tftp log
access-list 102 deny ip any 0.0.0.0 0.255.255.255 log
access-list 102 deny ip any 10.0.0.0 0.255.255.255 log
access-list 102 deny ip any 127.0.0.0 0.255.255.255 log
access-list 102 deny ip any 169.254.0.0 0.0.255.255 log
access-list 102 deny ip any 172.16.0.0 0.15.255.255 log
access-list 102 deny ip any 192.0.2.0 0.0.0.255 log
access-list 102 deny ip any 192.168.0.0 0.0.255.255 log
access-list 102 deny udp any any eq 135 log
access-list 102 deny tcp any any eq 135 log
access-list 102 deny udp any any eq netbios-ns log
access-list 102 deny udp any any eq netbios-dgm log
access-list 102 deny tcp any any eq 445 log
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip any host 255.255.255.255
access-list 102 deny ip any any log
dialer-list 1 protocol ip permit
control-plane
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 2 in
login local
scheduler max-task-time 5000
end
235
